Jabber for android registration issue
Operepichay
I used this video for IM and Presence configuration
https://supportforums.cisco.com/blog/12302201/configure-cucm-105-and-im-presence-105
Cisco jabber for windows connects to IM & P, makes calls, search contacts in LDAP and is registered to CUCM.
Cisco jabber for android also connects to IM & P, but only Instant Messaging is supported, there is no call icon and contacts search in LDAP. It is not registered to CUCM.
What can be wrong?
j.huizinga
Level 6
Level 6
On the BOT device page you must fill in the domain name
JH
Now I have call icon like in jabber for windows, but no luck in connecting both to IM and CUCM. After I entered login and password I accepted certificates from CUCM Pub, Sub and IM&P with their IP's and IM&P FQDN. In System - Server settings all my servers are configured with IP's not names.
Not sure if it works without DNS and FQDN. I am never using IP's anymore. And when you would use MRA, then it definitely needs some DNS configuration.
Maybe some one else can give some clarification on this
JH
I changed IP to FQDN in System - Server.
After jabber reset:
1. I enter name@corp.com and accept cucm-pub.corp.com, cucm-sub.corp.com and cucm-imp.corp.com certificates
2. I enter name and password and accept cucm-imp.corp.com certificate and get error
Cannot locate server. Check your server address. cucm-pub.corp.com is accessible from my android phone.
