Records CMS / DNS records for external users.
akram.root
Level 4
Level 4
Hello all,
I would like to impelemnt this scenarion with my costomer and i nned your help:
Concerning the A and SRV records required for MRA/B2B/ and WebProxy for CMS webbridge over Expressway:
Action plan:
  • 1) - MRA:
A Record: expe.lab.com --> Expressway E public IP
SRV Record: _collab-edge._tls.lab.com SRV  port 8443 --> expe.lab.com
  • 2)-Web proxy :
A Record: join.lab.com --> Expressway E public IP
  • 3)-B2B calls:
_sip._tcp.lab.com SRV port 5060 --> expe.lab.com
_sips._tcp.lab.com SRV port 5061 --> expe.lab.com
_h323cs._tcp.lab.com SRV port 1729 --> expe.lab.com
sip._tcp.conf.lab.com SRV port 5060 --> expe.lab.com
_sips._tcp.conf.lab.com SRV port 5061 --> expe.lab.com
_h323cs._tcp.conf.lab.com SRV port 1729 --> expe.lab.com
internal domain : lab.com end external domain : lab.com
For the certificate on expresswayE , what i need the generate in the SAN?
Best regards
Akram
You need to have
  • expe.lab.com
  • join.lab.com
  • conf.lab.com
Response Signature
Thank you for your reply,
for the  A and SRV  records are correct?
i want to use join.lab.com as webbridge3 on internal and external .
Best regards
external DNS :
join.lab.com should resolve to expressway E fqdn
Internal DNS
join.lab.com should resolve to call bridge (CMS) fqdn
