Snap Camera not working with Cisco Jabber 12.0 and up..
homeflash
Hi .. don't know if anyone has this issue.
I have snap camera installed (any version) works with Cisco Jabber 11.0; however, as soon as I updated Cisco Jabber to 12 or up.. It does not detect Snap Camera video.  I don't think it is the Snap camera because it works on Zoom and many video application, but if I downgrade cisco jabber back to 11.0 and it will work.
Can that bug be fixed?
Adam Pawlowski
I don't recall which version it happened in, but Jabber for Windows changed the way it was handling video cameras. This broke the virtual camera driver I used, causing the video to appear garbled. Somewhere between there and where we are in 14 today, that stopped being a problem. Perhaps the way that the snap camera presents itself to the platform has an issue with however this has changed.
Jabber 11 is no longer supported, are you able to try the latest 12.9/14.0 releases? That's be the best I can recommend, but at least with those versions you can attempt a TAC case to see if they'd be able to support this issue.
