Voice gateway - call block the calling number on sip interface
wilsonsant
Level 6
Level 6
Hi Guys,
I need to block the specific number in the inbound. I apply the configuration below, but, didn´t worked. Any have idea about this:
voice translation-rule 90
 rule 1 reject /XXXXXXXXXX/
voice translation-profile call_block
 translate calling 90
dial-peer voice 1001 voip
 call-block translation-profile incoming call_block
 call-block disconnect-cause incoming call-reject
 incoming called-number XXXXXXXXXX
Wilson
6 Replies 6
Jonathan Schulenberg
The config looks alright and matches the documentation: https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
Verify that dial-peer 1001 is matched for the incoming call leg and that the calling number matches the pattern you have defined in translation-rule 90.
Is the "called" number in e164 format with + ?
If so then it would have to look like this............. rule 1 reject /\+XXXXXXXXX/
Please remember to rate useful posts, click on the stars below.
marina.kaminski
I believe you need to apply it to the POTS dial-peer
Call Blocking Specific Calling Numbers
Configure a voice translation rule to block the desired calling number you want to block. This example uses 9193927393.
voice translation-rule 1
 rule 1 reject /9193927393/
!--- Matches the defined number string and rejects the call.
!--- Apply the rule to a translation profile for the calling number.
!--- You could also reject based on called or redirect-called numbers.
 translate calling 1
!--- Invokes voice translation rule 1 in order to determine
!--- which calls to reject based on the calling number.
!--- Include the translation profile within a dial peer definition.
dial-peer voice 100 pots
!--- Invokes the voice translation profile “call_block” on
!--- inbound POTS calls that match this peer
!--- in order to determine which calls to reject.
!--- Matches this peer for all inbound POTS calls.
 port 1/1:23
alwayslearning
Did you figure this out? I am also trying to block a specific calling number and having trouble with it.
I would recommend to open a new post about your problem. This thread is already some years old and I don't think you won't get any reply by the original poster.
I did see that its an older post. I was just hoping to get a response since I was having the same issue. I did figure it out. I was having trouble because the calls were using a dial peer I did not expect. Now that I have the translation profile applied to the appropriate dial peer it's working.
