Answered/handled distribution - Need help with too many rows
roberteliasson
I need some assistance with the script below, it returns multiple rows for each Agent.
I assume it has to do with the DateTime statement, but I can´t come up with a solution to remove it. (See the bold red text below)
Anyone got any idea on how I can reduce this to 1 row per Agent?
Thanks in advance!
SELECT
(Person.FirstName + ' ' + Person.LastName) as FullName,
Agent_Team.EnterpriseName as TeamName,
SUM(ASGI.CallsAnswered) as CallsAnswered,
SUM(ASGI.CallsHandled) as CallsHandled
FROM
(Select DateTime,
SkillTargetID,
CallsAnswered = SUM(ISNULL(CallsAnswered,0)),
CallsHandled = SUM(ISNULL(CallsHandled,0))
FROM Agent_Skill_Group_Interval
WHERE SkillTargetID IN (:SkillTargetID)
and DateTime >= :startDate
and DateTime <= :endDate
GROUP BY DateTime, SkillTargetID) ASGI
LEFT JOIN Agent
ON Agent.SkillTargetID=ASGI.SkillTargetID
LEFT JOIN Person
ON Person.PersonID=Agent.PersonID
LEFT JOIN Agent_Team_Member
ON Agent_Team_Member.SkillTargetID=Agent.SkillTargetID
ON Agent_Team.AgentTeamID=Agent_Team_Member.AgentTeamID
WHERE  ASGI.SkillTargetID IN (:SkillTargetID)
and ASGI.DateTime >= :startDate
and ASGI.DateTime <= :endDate
GROUP BY
Agent_Team.EnterpriseName, ASGI.DateTime, ASGI.SkillTargetID, Person.FirstName, Person.LastName
One error I see: "COUNT(TCD.CallsCoded) as CallsCoded" in your first SELECT statement should be a SUM instead. Counting something that's already summarized is likely to give you a value of 1 for CallsCoded for each agent.
A couple things to note on DateTime values... you'll want to keep these in mind:
  • All DateTime values in Agent_Skill_Group_Interval are for the interval as a whole... So if you have 30-minute intervals in your system, a row for 10:30AM has data from 10:30:00AM to 10:59:59AM. Statistics like CallsAnswered, CallsHandled, etc. are incremented in the interval they occurred in, so you can have a call Answered in one interval, and Handled in the next.
  • All DateTime values in Termination_Call_Detail are for when the call leg completed.
So, if your DateTime filter criteria is something like October 21, 2014, 10:30 AM to 11:00AM, you'll see Agent Skill Group data for calls that were answered between 10:30:00 and 11:29:59, calls that were handled (completed wrapup) in that same interval, and you'll see TCD data for calls that completed between 10:30:00 and 11:00:00.
It may be possible to change the TCD part of your query to automatically handle the Interval-DateTime differences.
-Jameson
-Jameson
7 Replies 7
Robert,
Remove "ASGI.DateTime" from the final GROUP BY statement, and you should be down to one line per agent.
In fact, I'd probably re-write the whole thing as a regular query instead of an anonymous block... your sub-query looks unnecessary to me. This is a simpler query, and gives you the benefit of better filter selection:
SELECT
FROM Agent_Skill_Group_Interval ASGI
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
Agent_Team.EnterpriseName, ASGI.SkillTargetID, Person.FirstName, Person.LastName
In the Fields tab of the report definition, you can create Filter Fields for ASGI.DateTime and ASGI.SkillTargetID. CUIC will automatically do the "WHERE" portion of the query from those.
-Jameson
-Jameson
Thanks a bunch Jameson, that made the trick!
I´ve continued with the query now, with adding the figures 'calls coded' a.k.a. number of wrap up codes. This is the reason why I´m creating this script - to see the split between answered calls and coded calls.
For some reason I´m not getting all coded calls though.. It doesn´t show the correct figure. Do you have any idea why?
SELECT
SUM(ISNULL(ASGI.CallsAnswered,0)) as CallsAnswered,
SUM(ISNULL(ASGI.CallsAnswered,0)) as PerHandled,
FROM
(Select DateTime,
SkillTargetID,
LEFT OUTER JOIN (SELECT
AgentSkillTargetID,
CallsCoded = COUNT(WrapupData)
FROM Termination_Call_Detail
WHERE  AgentSkillTargetID IN (:SkillTargetID)
and WrapupData is not null
GROUP BY AgentSkillTargetID
) TCD
ON TCD.AgentSkillTargetID=ASGI.SkillTargetID
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
-Jameson
-Jameson
Jameson,
Thank you so much for your explanations! However - I will only run this report on a monthly basis between 01:00AM and 12:00PM, so it shouldn´t be a problem - right?
I changed the COUNT to SUM but now it gives me a really high value instead, see the screenshot below.
The proper value of the 2nd row which shows 18 and 588 should be 31 (when looking at the Supervisor Desktop log)
Here´s the script:
SELECT
COUNT(TCD.CallsCoded) as CallsCoded,
SUM(TCD.CallsCoded) as CallsCodednew
FROM
(Select DateTime,
SkillTargetID,
AgentSkillTargetID,
) TCD
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
roberteliasson
FYI I just solved it, here´s the query in case anyone needs something similar.
Thanks for the help Jameson!
SELECT
SUM(ISNULL(TCD.CallsCoded,0)/ISNULL(ASGI.CallsAnswered,0)) as PerHandled,
SUM(ISNULL(TCD.CallsCoded,0)) as CallsCoded,
SUM(ISNULL(ASGI.CallsAnswered,0)-ISNULL(TCD.CallsCoded,0)) as CallsNotCoded
FROM
(Select DateTime,
SkillTargetID,
and SkillGroupSkillTargetID IN (:SkillGroup)
Interval=CASE WHEN (DATEPART(minute,DateTime)<>0 AND DATEPART(minute,DateTime)<>15 AND DATEPART(minute,DateTime)<>30 AND DATEPART(minute,DateTime)<>45) OR DATEPART(second,DateTime)<>0 THEN DATEADD(minute ,((DATEDIFF( minute,0 , DateTime)/ 15)*15 ),0) ELSE DATEADD(minute ,(((DATEDIFF( minute,0 , DateTime)-1)/ 15)*15 ),0) END,
AgentSkillTargetID,
CallsCoded = COUNT(ISNULL(WrapupData,0))
GROUP BY AgentSkillTargetID,
) TCD
ON TCD.AgentSkillTargetID=ASGI.SkillTargetID AND TCD.Interval=ASGI.DateTime
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
Agent_Team.EnterpriseName, ASGI.SkillTargetID, Person.FirstName, Person.LastName, TCD.AgentSkillTargetID
That looks good, Robert. Glad to see it's working.  In the interest of further optimization...
One alternative solution would be to remove all DateTime grouping and selection from each of your sub-queries. Looking at your earlier query that has both the Count and Sum columns, I see that the Count value is actually the number of different DateTimes from the ASGI sub-query. If you did SUM(CallsCoded)/COUNT(CallsCoded) in that earlier query, you would see the same result as your last query.
Removing all DateTime references (aside from the WHERE statements) would make the SQL a little easier to read, and a little faster to run. Here's what I mean:
SELECT
FROM
(Select
SkillTargetID,
GROUP BY SkillTargetID) ASGI
AgentSkillTargetID,
) TCD
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
I also removed your final WHERE statement, it should be unnecessary as you're already filtering on the SkillTargetID and DateTime in your sub-queries.
-Jameson
-Jameson
Indeed Jameson, that looks so much better! I´ll do the changes according to your tips and trix.
Thank you so much!!
