08-17-2022 05:38 PM
Hi all,
Currently trying to trouble shoot an issue. Recently installed Jabba (12.9.6) which is working as intended, can make and receive calls without issue. When using finesse in conjunction with Jabba to answer a call (using the finesse answer button) the call connects but there is no audio heard by either the call taker or call maker.
Has anyone experienced this issue before, or have any guidance on ow to resolve?
Any information greatly appreciated.
Matt
08-18-2022 12:27 AM
Hey
Just so i understand it.
or is the problem only on Contact Center calls ?
08-18-2022 01:15 AM
Hi Thomas.
Thanks for the reply.
correct, the Issue is on direct calls to the agent number when answering via finesse. The agent is in not ready mode (I've not tried in ready mode as yet on account of it not working in not ready mode).
Call answering via finesse works fine when not being using in conjunction with Jabba.
Thanks again.
Matt
08-18-2022 05:28 AM
Something's not right then. If the agent is not ready in Finesse and you try and send them a call, they shouldn't get it, the call should queue. Or are you referring to agent to agent direct calls? We've seen an issue where agent was in do not disturb with Jabber and agent couldn't get the call for instance. So make sure you're ready/available in Jabber and use Finesse to determine when you can get ACD/queue calls.
08-18-2022 06:49 AM
Hi Bill,
Yes, agent to agent calls, I've not attempted queue calls yet as I assumed they would have the same audio issue. I will test tomorrow to confirm. Jabba was in the ready state when attempting the calls. I've replicated my settings onto the agents system (I don't have any audio issues), the only difference is our headsets. But given the headset works with jabba calls it makes me think its a finesse issue. I will go back and review all the settings to make sure I haven't missed something.
Thanks for the assistance.
08-18-2022 10:45 AM
Hi, another thing you might be able to try based on the headset is use it with a physical phone, to eliminate that out of the equation.
And this might be a dumb question on my part, but you're talking about Cisco Jabber, not Jabra headsets right? Or both?
08-18-2022 05:29 AM
@bill.king1 I read it as it is direct calls to the agent extension.. Not CC calls
08-18-2022 05:36 AM
Hey Matt
Have you tried to pres CTRL+SHIFT+s under a call that doesn't have audio.
Here you can see the network traffic - if any :-).
Please post a screendump of that.
and also with a call that has audio. (So we can compare)
08-18-2022 06:50 AM
Thanks Thomas, I'll do that tomorrow, and post the results.
