03-19-2018 07:02 AM - edited 03-14-2019 06:02 PM
Hello everyone,
I'm trying to setup a recording solution using CCX, CUCM and Quality management.
Followed the documentation provided by Calabrio team, choosed the BiB recording model, and installed different requirements such as SQL server etc ..
My problem now when I try to install QM, I have the following message :Could not get a database connection: Server "IPaddress_Of_the_server" has no instance named MSSQLSERVER
the screenshot in the attachments section shows the error
Any idea what could be the problem ?
thanks in advance
03-19-2018 01:49 PM
Are you using an instance other than the default instance?
If you're using the default instance, you have to leave that field blank as per the documentation says.
Rgrds.
03-19-2018 05:14 PM - edited 03-19-2018 05:14 PM
Hi Can you make sure that the SQL server instance name you are running is exactly what you are adding here in the configuration interface, below link shows how you can find the instance name.
https://sqlserver-help.com/2011/06/19/help-whats-my-sql-server-name/
03-20-2018 03:10 AM
03-20-2018 03:09 AM
