ā10-12-2016 07:28 AM - edited ā03-14-2019 04:39 PM
We are using CAD-Finesse mixed mode with 10.6(1)SU2 and now almost all agents are familiar with Finesse. We need to now slowly phase out CAD. Is there anyway we can prevent the agents from logging into CAD. Uninstalling is an option, but is there a better way like disabling some services meant only for CAD. The intention is if we want to use CAD later on, we can simply enable the services.
We also have some agents who use IPPA.
Kindly provide your valuable suggestions.
ā10-12-2016 10:52 AM
Libin, feel free to stop all the services under Desktop Services section by going into Cisco Unified CCX Serviceability as they are only responsible for CAD and IPPA and nothing else.
I am also attaching a screenshot of CCX serviceability page from UCCX 11 version in my lab wherein you will see there are no Desktop Services in it since it is all Finesse starting 11.x
Deepak
ā10-13-2016 03:40 AM
Hi Deepak,
Thanks for the response.
The problem is that we have a few IPPA agents who will continue to use the same.
If we disable the Desktop Services, IPPA agents will also be affected? Or IPPA use Finesse instead of CAD in 10.6(1)SU2?
How is IPPA functionality in UCCX 11.x?
Libin Benedict
ā10-13-2016 03:49 AM
Libin, in that case leave Browser and IP Phone Agent Service started that is for IPPA. Starting version 11, there is no IPPA but Finesse IP Phone Service. More details below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_0/config/guide/UCCX_BK_U2F148AE_00_unified-ccx-administration-guide/UCCX_BK_U2F148AE_00_unified-ccx-administration-guide_chapter_010110.html#CFIN_TP_F554A61F_00
Deepak
ā10-20-2016 12:55 AM
Hi Deepak,
Thanks for the advice. I will check this and let you know an update.
Libin Benedict
ā10-20-2016 05:10 AM
No issues Libin, please remember to rate helpful posts and mark the answers as Correct when applicable so that these posts can stay on top and help others with similar issue in the community.
Deepak
ā10-25-2016 02:43 AM
Hi Deepak,
I stopped the Desktop Services on both PUB and SUB except the Browser and IPPA Service.
1. Now it shows the VOIP Monitor Subsystem Out of Service. Does this have any impact on the functioning of the call center?
2. We have Calabrio Recording in place. I see that some Desktop services are for Recording (for eg, Cisco Desktop Recording and Playback Service and Cisco Desktop Recording and Statistics Service).
Kindly advise.
Thanks and Regards,
Libin Benedict
ā10-25-2016 10:03 AM
Answer: This will only come into picture if you are using UCCX for monitoring and recording purpose
Answer: Calabrio does not use these Desktop services, they will only come into effect if you are using UCCX for recording and monitoring but since you are using Calabrio for this, that should not be a problem.
Deepak
ā10-28-2016 02:21 AM
Hi Deepak,
Thanks for the clarification.
Here is what happened for IPPA agents:
I stopped all except Browser and IPPA Service under Desktop Services, but IPPA requires Cisco Desktop LDAP Monitor Service (we got some LDAP error while launching IPPA) and Cisco Desktop License and Resource Manager Service (for license). So we had to enable both these services again and this made CAD available for login and take calls.
So, we have advised the IPPA agents to start using Finesse so that we can stop all of the services under Desktop Services.
Libin Benedict
