02-27-2012 08:44 AM - edited 03-14-2019 09:26 AM
I am using the Advanced Queues script provided in Cisco Script Repository and am able to queue a recording to the next available agent. However, when I tried to queue this recording overnight, the call has disappeared after 30~31 minutes. Any idea to correct this issue?
Thanks in advance.
Michael
02-27-2012 09:07 AM
Hi Michael,
Do you have any Max Retries mentioned for the prompts being played when the Caller is place in the Queue?
Anand
02-27-2012 09:12 AM
Can you post the script you are using?
Chris
02-27-2012 06:08 PM
One thing to consider, even though this usually doesn't happen after just 30 minutes, is that the system defaults to a "maximum number of executed steps" of 1000. Since you said that the call disappears over night, I thought I would through this out there. You may want to debug the script and see what error you get when the call drops. This should be fairly easy since the call drops after only 30 minutes. Like Chris, I'm also curious to see the script.
Good luck!
Larry
03-08-2012 03:42 PM
Out of the office and haven't check the forum for a while. I use the same script from Cisco Contact Center Express Script Repository.
You will see BaseLineAdvQueuing folder after unzip the file.
03-08-2012 03:47 PM
Another discussion for the same topic
https://supportforums.cisco.com/message/3574540#3574540
Any idea?
Thanks.
