05-22-2019 12:20 PM
One (and only one so far) agent we are not able to monitor.
The monitoring session starts, and the display on the supervisor phone shows their name, but there is no audio.
With other agents, it works fine.
Can anyone suggest some troubleshooting?
I have had the agent log out of EM and back in; I have confirmed that the hardware is set up identical to other working phones (as far as BIB and Monitoring CSS)
05-22-2019 01:46 PM - edited 05-22-2019 01:48 PM
Hi there
Which platform are you using? CAD or Finesse and also the UCCX version.
Most of the monitoring issues could be related to the firewall/anti-virus/port blocking etc settings on the Agent PC. Worth checking the below link as its identical to your case.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-23-2019 01:40 PM
05-27-2019 02:05 PM
