Can I have Cube and Vxml Gateway configured on same Router box ?
Anil Kumar
I have one router Model #3900 Series    Can I have Cube and Vxml Gateway configured on same router ?  If yes,  Can any one help me with sample configuration for same.
Thanks and Regards
Anil Kumar.
Chris Deren
Yes you can as combo (ingress/VXML) GWs are supported as long as you meet the IOS version compatibility.
As to config the VXML examples are in CVP guides, and CUBE would not require anything unique and config depends on your SIP provider, etc.
May I know compatible IOS which supports Cube and Vxml on 3900 Series router?  Please support.
Its depends on your CVP Version, Pls check respective H/W and S/W Specification Guide.
SIVANESAN R
Here is an example of CVP hardware/software compatibility for CVP 10.0, similar doc exists for each version of CVP.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/customer_voice_portal/cvp10_0/reference/guide/CCVP_BK_1ECCDBC7_00_1001-bom/CCVP_BK_1ECCDBC7_00_1001-bom_chapter_00.html
