Can we have more than 1 supervisor monitoring a single Call?
ayush.shyam
Hello All,
My question is, can we start more than 1 Silent monitoring session on same call?
Right now I am able to start monitoring by one supervisor and when i tried to start with second one a call is initiated but not connected.
Can you tell me if it's possible!
Ayush Chaudhary
Switzerland
keglass
Level 7
Level 7
Ayush,
I recommend you post this to the Cisco Support Community and include details about the services you are currently using. You will also find a number of informative questions on this same subject, so definitely have a look at prior posts.
https://supportforums.cisco.com/
I hope this helps,
Kelli Glass
Moderator for Cisco Customer Communities
Thanks for your reply.
