Connecting to external sql database using UCCX Script Editor
Mariela Montero
Community Member
Hello;
I am trying to write some data in external database from CCX script (UCCX 10.1), but DB Write step. I am using correct SQL syntax. I have checked it through MS SQL Management studio and everything works.  Another weird thing is that making test from "DB Write" step properties shows "Rows altered 1 or 2  but it really does not change anything on the database.  Also, what is the best way to use the DB write step?
Mariela
cristian.campos
Frequent Visitor
Frequent Visitor
Hi Mariela
To connect an external DB, you need :
1.- Install a  JDBC driver. (subsystem>Database>Drivers).
2.- Connects  to a external DB, add new DataSource and verified test connection (subsystem>Database>DataSource).
3.- Then you can use , DB Read, DB Get, DB Write.
To DB write select a database, enter SQL insert, update o delete statements.
e.g.
insert into TBL_IVR_OPERATION (ID,COD_OSIN,CLAVE_OSIN,FUNCION) values ($prID,$prUserID,$prPassword,'validaracceso').
Regards.
Gergely Szabo
"test" is test, so it's not supposed to change anything, it just validates your SQL syntax.
The best way to use it is to make sure you have a DB Release step in your script as well, in order to free resources.
G.
