CTI client can't failover to side A from side B
bo liu
Level 4
Level 4
hello everyone
now ,i have a question
i install ICM in a server and install PG CG CTI os server in another servier,of course the sideA and sideB always separate out.
the CTI clinet connected to CTI os server sideA,but when i shutdown the CTIOS sideA,or shutdown the server of PG CG CTI.the client display offline....
why this?
here is my config with CTIOS CG and PG
Dass Prakash R
Could you please check out the following points and update
1. Can you please check the connectivity from Agent Desktop to CTIOS Server (A and B Side)
2. Can you check the DNS configuration
3. You can also enter the CTIOS Server IP address and Hostname (A & B Side) in the host file of the Agent desktop and check whether you were able to connect
Hope this helps!!!
Dass
Please rate useful posts
5 Replies 5
bo liu
Level 4
Level 4
here is my CUCM PG's config
Dass Prakash R
Hope this helps!!!
Dass
thanks Dass
i'm not config the host file
HI ,
suspect you have some misconfiguration
In CTI server information : SYSTEM B , PORT : number value is misconfigured
Vigeesh Kalathil Mohandas
hi vigeesh
sorry .... the SYSTEM B config is the same with A.......whether i need change the side B prot difference from A?
