CVP 10.5.1 with Nuance changing language using built in grammar
Is there any way to use the built in grammars available via the Digits element to change the language?  We need to be able to make use of the es-ES language that is installed for Nuance Recognizer for menu options and digit collection (pay amounts, account numbers, dates, etc).  Seems that the built in grammar is hard coded with en-US so I am trying to determine if custom grammars are the only option.  Any thoughts or suggestions are appreciated.  Thanks!
In the settings field if you hover over the field I believe it tells you the format you can use to set the language. I'm going from memory but something like builtin/digits;lang=foo. Can you take a look at a that?
david
