10-17-2020 08:26 PM - edited 10-17-2020 08:32 PM
I am trying to post data to an external server but I can't seem to get the body of the request to work. I used multiple tools such as Postman and I am getting the result I need but all these tools understand multiple programming languages
Here is what I need to post in the body
mutation {
createCommunication(
communication: {
status: "needs_delivery"
priority: ""
category: ""
reasonCode: "wayfinding"
topic: ""
note: ""
medium: "sms"
payload: [{ contentString: "Test" }]
direction: "outbound"
intent: "info"
sessionID: ""
recipient: [
resourceType: "Patient"
telecom: [{ system: "phone", value: "646XXXXXXX", use: "mobile" }]
identifier {
value
I was able to get this to work in UCCX Script Editor by following the syntax below
u"{\"query\":\"# Write your query or mutation here\\nmutation {\\n createCommunication(\\n communication: {\\n status: \\\"needs_delivery\\\"\\n priority: \\\"\\\"\\n category: \\\"\\\"\\n reasonCode: \\\"wayfinding\\\"\\n topic: \\\"\\\"\\n note: \\\"\\\"\\n medium: \\\"sms\\\"\\n payload: [{ contentString: \\\"UCCX Testing\\\" }]\\n direction: \\\"outbound\\\"\\n intent: \\\"info\\\"\\n sessionID: \\\"\\\"\\n recipient: [\\n {\\n resourceType: \\\"Patient\\\"\\n telecom: [{ system: \\\"phone\\\", value: \\\"" + REST_callbacknumber + u"\\\", use: \\\"mobile\\\" }]\\n }\\n ]\\n }\\n) {\\n identifier {\\n value\\n }\\n}\\n}\\n\"}"
10-18-2020 05:38 AM
When I enter your json into jsonpathfinder dot com - I get this error
There seems to be a problem with your JSON.
Error message: JSON.parse: unexpected character at line 1 column 1 of the JSON data
I've never seen valid json that has the format you posted.
10-18-2020 05:38 AM
What version of CVP do you have, there was a REST Client bug regarding post w/json a while back...
10-18-2020 05:39 AM
It'll also be helpful if you log the element data named status_code and response_body so we can see what the return error message actually contains
10-18-2020 06:35 AM
Janine - thanks for the reply. Here is more information
JSON code that is valid by checking multiple tools but does not pass validation in call studio
{"query":"mutation {\n createCommunication(communication: {status: \"needs_delivery\", priority: \"\", category: \"\", reasonCode: \"wayfinding\", topic: \"\", note: \"\", medium: \"sms\", payload: [{contentString: \"Hello World\"}], direction: \"outbound\", intent: \"info\", sessionID: \"\", recipient: [{resourceType : \"Patient\", telecom: [{ system : \"phone\", value: \"9171234567\", use: \"mobile\"}]}]}) {\n identifier {\n value\n }\n payload {\n value\n }\n }\n}\n"}
Error on validation - it feels that is related to the area in regards to response values at the end
Action Element: Rest_Client_01 Configuration error: The value of the setting "Body" contains substitution errors: "{\n value\n}": Invalid Key: \n value\n
10-18-2020 06:41 AM
You didn't say what version, but Janine might be right on the money as always, the brackets may be the problem if you're hitting this bug.
10-18-2020 07:15 AM
replace all the \" with apostrophe ' (no back slash)
and remove the \n
10-18-2020 07:21 AM
The workaround may be to use the Set Value element to assign your json query into a LocalVariable. Then use the value of that LocalVariable in the rest client element Body Setting.
11-13-2020 06:46 PM
Janine,
Sorry for my late response but I've tried everything and either it does not pass validation or the Set Value element does not accept the code. I am running version 11.6.1 and was wondering if anyone can post an example of Rest_Client post using Application/JSON
I created a Cisco case and the code provided gives me an error on transport from all rest clients used
I appreciate any input on this issue
11-14-2020 01:59 PM - edited 11-14-2020 02:41 PM
I think I might've figured out what is happening (not to be mistaken with the issue being resolved) and why I am getting errors on validation. From the example below I get validation errors due to (name) which I guess Call Studio thinks its a substitution, I tried using the Set_Value step but I am running into the same issue
Validation error: Project Location Description Creation time Id
Countries Action Element: Rest_Client_01 Configuration error: The value of the setting "Body" contains substitution errors: "{name}": Invalid Key: name 1605391251997 752
Postman troubleshooting with the info below is successful
URL https://countries.trevorblades.com HTTP header Content-Type application/json RAW body {"query":"query {countries{name}}","variables":{}}
11-14-2020 02:47 PM
11-14-2020 02:54 PM
11-14-2020 03:32 PM
Janine, you are 100% correct adding the code between single quotes helps with the validation but it appears that Call Studio is sending these single quotes as well and I get a bad request . After you mentioned this I added tried
11-14-2020 05:29 PM
Try this in the SetValue element. Perhaps it'll omit the quotes.
var obj = {"query":"query {countries{name}}","variables":{}};
JSON.stringify(obj);
11-14-2020 06:09 PM
Validation checks are successful but on debug there are java error on SetValue element
