facing problem to Use a custom Java class in UCCX
We are using Communication manager 7.0.1 and UCCX version 7.0.1(Cisco Unified CCX Premium).  We are trying to call a Custom Java class file from UCCX scripting. We have followed the steps mentioned in the guide (How-To: Using a custom Java class in UCCX 5.x (SOAP Example)). See below link.
http://www.avholloway.com/vtools/ipcc/custom-java/soap/
After completed all the steps we have got the variable type SimpleSOAP at script but we did not found it to object constructors or object attributes (plz find the attached screenshots). We will appreciate if you plz guide us to solve the issue.
Fakhrul
LEADS Corporation Ltd.
Paulo Pereira
Hello, Fakhrul.
I'm sorry to see you were not able to find the information or help you were looking for here in the Contact Center community forum.
You may be able to find more help through the Cisco Developer Network.
Also, you might want to consider engaging Cisco Advanced Services via your account team to assist with UCCX custom scripting.
Thank you, and good luck.
-Paulo
