Finesse 9.1(1) - Manage Call Gadget issue
I upgraded the Finesse from 9.0(1) to 9.1(1).
Now when the Agent gets the following error. Any idea why? It appears the CallControl.xml file is the culprit?
How do you go about fixing this issue?
Purush
There were issues rendering this gadget.
org.apache.shindig.common.xml.XmlException: The element type "meta" must be terminated by the matching end-tag "". At: (20,3)
http://localhost/desktop/gadgets/CallControl.xml
Had the same issue. In your layout rename CallControl.xml to CallControl.jsp . That should fix it right up.
Jeff
5 Replies 5
yes, it looks like issue in the XML file.
Did you take a look into it?
If you are not sure what to search for, share that file with us.
Martin
No I can't access the file. Finesse is using VOS. Not sure if there is access to the files.
Jeff
Jeff,
That worked !
Thanks for the tip. Appreciate it.
Nice little gotcha
-Purush
I added a screenshot for those in case others need to see where I changed it. See below.
