Finesse dropped calls after 10 seconds
roshan1022
Having issues with UCCE 12.5 Finesse, web based.  Calls keep dropping after 10 seconds.  Is anyone having this issue or know what can be causing this?
ritdesai
hi @roshan1022
is for all the agents ur facing or with particular user?
Finesse webservice logs and ICM Agent PG ctisvr logs would give you more clarity.
thanks and regards,
Ritesh Desai
Please mark useful if it helps you. Mark answered if it is answered.
pawanyadav.pjy
finesse is getting logout Automatically in every 2-3 mins, what to check getting error 50003 in Aw-server in agent event details.
This often means that the device they were logged into went out of service/logged off, which then kills the Finesse session. to the agent they think it is a Finesse problem but it is likely a UCM problem. You can likely confirm it in the UCM logs.
