finesse question about audio
jdickinson
Level 5
Level 5
Is there a way to play recorded audio using finesse?
7 Replies 7
dekwan
Do you mean through the call? Or do you mean on the client machine from the agent desktop. From the call, not that I know of, unless there is a CUCM feature that allows it.
Thanx,
Denise
I think we want the user to be able to send the call to a recording, that essentially ends the call.
That might be able to be done via CCX with a script, but I am not sure. I haven't done it myself.
THanx,
Denise
is there a way to execute a UCCX script from finesse?
The agent would need to transfer the call to the ivr/RP
So to clarify you are saying, we  could have a gadget button to ask the call to be transfered to an ivr/RP recording.
Or should the agent transfer manually? It may be easier to have a button...
This is all theoretical based off of what I know about Finesse and UCCX, but yes. You can have a button on a gadget and have the RP number hardcoded. The only thing is if the agent has more than one call, you will need to determine which call gets transferred.
Thanx,
Denise
