Get Digits ext script not working. DTMF issue with Audio Codes Mediant 1000.
Ritesh Desai
Hi team,
I have UCCE Lab setup and working on ICM Script Editor. I've basic call flow, Snap attached for reference. Am beginner in UCCE.
I tried 3 digit Menu, capturing it and route to agent. My basic call flow is working. My call hits Get Digit Ext Script element. Prompt plays to press 1,2 & 3. DTMF is not passing and doesnot moves to next node....
Nyone have experienced before please help... TIA
regards,
Ritesh Desai
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
17 Replies 17
Hi Chintan,
Thanks for revert.
First, you have asked for CVP call server logs, are you refering to this loc. logs C:\Cisco\CVP\CallServer\Tomcat\logs.....?
If yes, last logs file generated is 12Aug of catalina.txt
OR else you're refering to ICM logs?
Secondly, was unable to configure "dtmf-rely rtp-nte sip-notfy cisco-rtp" command on 3 DP's. DP for CVP VRU 81111111 is not accepting this command. So, understanding the same dtmf relay on 3 DP's logic, I configured
"dtmf-relay rtp-nte cisco-rtp" on 3 DP's.
Though badluck!
the logs can be found at c:\cisco\cvp\logs
try this dial-peers:
dial-peer voice 811111 voip
 description CVP IVR dial-peer
 service bootstrap
 session transport udp
 incoming called-number 8111T
 voice-class sip rel1xx disable
 rtp payload-type nte 96 comfort-noise 13
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1002 voip
 description CVP VXML Standalone application dial-peer for a VOIP call
 destination-pattern 3011
 session protocol sipv2
 session target ipv4:192.168.3.142
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1001 voip
 description Incoming from ACM1000
 session transport tcp
 incoming called-number 8896
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
let me know if it works, and have your old configuration backed up as well
and also if it doesn't work please attach the below logs:
debug ccsip messages
and call server logs.
