06-25-2018 01:56 AM - edited 03-14-2019 06:16 PM
I am wondering If there is a method to make finesse agent to write comments or notes after call on its finesse desktop without third party app ?
Please I want a detailed document how to do it from scratch as I am a beginner in UCCX.
I found that link but I couldn't understand anything
https://github.com/CiscoDevNet/finesse-sample-code/tree/master/UpdateCallVariableDataSampleGadget
Solved! Go to Solution.
06-25-2018 07:42 AM
Hi there
One thing you could use is Wrap up codes in UCCX.
The other option is you can create a gadget if you are using Finesse.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-25-2018 07:42 AM
Hi there
Hope this helps!
Cheers
Rath!
06-25-2018 07:54 AM
I am using Finesse and opened this link but I couldn't understand
06-26-2018 01:23 AM
I am sorry, Can you help me with this case please ?
