11-26-2004 06:06 AM - edited 03-13-2019 10:34 PM
Where in the CallManager can I see what is the total weight of all registered IP Phones (CTI controlled), CTI ports and CTI route points, as one counter (summ)?
If it is calculated manually, what are the correct weights for devices mentioned above in the IPCC?
12-03-2004 07:18 AM
The following document has more details on CTI device weight.
http://www.cisco.com/warp/public/570/downloads/level_3/CTI_Apps.pdf
12-06-2004 08:32 AM
I am logged in but I still cannot access the doc. Can you post it so we can download from the forum? thanks
12-06-2004 12:22 PM
Hope this helps,
Weights for
IP phone - 1,
DS0 port,- 3
Transcoding resource - 3,
Conference resource -3,
TAPI - 20
JTAPI - 20
CTI ports and route points fall under JTAPI so count 20 for each one of them.
The total device units of all devices configured cannot exceed the maximum device units the Cisco Media Convergence Server (MCS) is capable of supporting. The maximum device units supported by the MCS is based on the server model.
thx,
Aslam.
