IPIVR connection to business systems
Robert.hamlin_2
Is it possible for a IPIVR to use SSL when conencting to a business system gateway for processing credit cards ? Let me add to this, usng the java method.
Gergely Szabo
the short version: yes, that's possible, but...
The longer version: yes, that's possible, but you'll have to do some Java programming around it.
If I were you, I would build a Java package that would use Apache HTTPClient for connecting to the business system. Take a look at this: http://hc.apache.org/httpclient-3.x/sslguide.html
G.
Anthony Holloway
This works without any Java programming:
HTTPS GET
set https_response = url["https://mail.google.com/"]
HTTPS POST
set https_response = url["https://mail.google.com/", text[key1=value1,key2=value2]]
