IPIVR/UCCX 8.0 upload script not updating script.
david.macias
In my lab I have IP IVR 8.0, fully patched running on ESXi 5.  What I've noticed is that when I upload a new script it shows to upload correctly, but when I call in it plays the old script.  If I use the script editor and open the script from the repository, the script that opens up is the new one.  When I set reactive script and make the call the old script pops up when the call arrives.  I'm stumped... I'm looking to see what kind of logs I should be looking at in order to troubleshoot this or if anyone has seen something similar would love to hear about it.
david
Try refreshing the application the script runs under, and then the script.  I'm not sure if the app recompiles the script, but I've had this issue since we rolled out 7.x, and I've just made this part of my standard deployment for script updates due to it.
6 Replies 6
Graham Old
Level 7
Level 7
You see this on HA systems if you connect the editor to the Standby server. You can save and refresh via appadmin but the Active Engine just won't go and get the new copy from the repositry.
I have never seen it on a single server system. Have a look at the Engine/MIVR logs.
Graham
michael_cole
I'm guessing you've already done this but did not mention it in your post - refresh the Application...
Yeah refreshing the script does nothing, I can even delete it and it will still play when I call the DN.  I'll look through the Engine/MIVR logs, this is really stomping me.
david
Thank you thank you thank you, such an easy fix and it works like a champ!
david
Glad to hear!
