I have this question because I create a custom SayItSmart plugin to play alpha numeric string. And I saw the java code online that is way to create static Audio like following:
AudioGroup init_audgrp = cfg.new AudioGroup("initial_audio_group", false);
StaticAudio tts = cfg.new StaticAudio(prompt, null);
init_audgrp.addAudioItem(tts);
init_audgrp.setBargein(false);
//cfg is VoiceElementConfig
cfg.setAudioGroup(init_audgrp);
And I look at the source code for SayItSmart part, it cannot create the custom type like using following:
String id = IDs[i -1];
SayItSmart IDSayItSmart = cfg.new SayItSmart("AlphaNumeric", "com.vincent.sayitsmart.ItspSayItSmartAlphaNumeric", ID);
init_audioGroup.addAudioItem(policyIDSayItSmart);
When I run that it will throw following exception:
Caused by: com.audium.server.xml.ElementConfigException: There is no Say It Smart plugin of type "AlphaNumeric".
So is it any way I can create the sayitsmart audio item for voice element config to use?
