Is there a way to modify a scripts range of hours to include smaller increments of time?
tdederscheck
I am using UCCX enhanced v. 9.02 and need to create a script that will check for logged in agents based on shift changes.  So I would need to look at seconds for the start and or end times.  The Time of Day will not allow me to adjust the minutes or seconds outside of the 15min increments.
Graham Old
Level 7
Level 7
I think the enhanced versions supports the T[now] item.
Run this as a test in your editor
If enhanced supports this you can  then work out your open and close time in minutes or seconds depending on the resolution you require.
Then its a simple test.
If TimeNow > OpenTime && TimeNow < CloseTime
    // we are open
else
   // We are closed
Please rate helpful posts.
Graham
