Issues running Reactive Debugging
kbeaton
Level 5
Level 5
I'm trying to Reactive Debugging on a Script I need to test.
I have the Application created with a Trigger
The path to the Script is correct, but when I dial the trigger 7003 the Reactive Debugging doesn't recognize I'm calling the number
The Debugging doesn't recognize that I'm calling the number
What am I missing that would cause this?
Does the script work as expected when you dial it, is it "just" the reactive debugging that isn't working? If so, there are a couple older defects like this one that you might want to compare to see if you're hitting.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCul07095
david.macias
I can almost guarantee you that the trigger is off or the app is off or you're calling a sub flow which will not work. Confirm that trigger is actually the one getting hit by the call and it's not doing a forward or some other UCM magic.
david
