MakeConsultCall optional paarmeters do not work
Alex_Mazilo
Hi, I'm using CTI OS and  making a consult call type 2, which works file except its optional parameters AlertRings and AnsweringMachine have no effect on the call. I set both parameters to value 2, but the call is not disconnecting after 2 rings and it is not disconnecting on answering machine.
The parameters are accepted as I see in the CIL log:
{Thread-49} [call.5004.51630787.1110226].MakeRequest: (ConsultType:2 AlertRings:2 AnsweringMachine:2
Are there any settings that may prevent this values to override the default values?
Thanks for your help.
dreich
Apologies for the confusion.
Those parameters are not supported.
David
dreich
David
