max agents logged in and max calls on CVP
kavle
Level 3
Level 3
Hi All,
need some help on how to check maximum agent logged in to any PG and also max number of call hit the CVP in the last week.
I am not sure which table on the HDS has this details , I can check the real time data  but not sure on the historical .
Lok in the CUIC standard license consumption report that Cisco provides, that will give you max concurrent agents. CVP is a little trickier since depends on exactly what you're looking for (CVP ports, VMXL ports, something else).
Some of these may also be available to you if you're on a system with Smart Licensing as well, since Cisco will be watching this usage.
