06-19-2018 08:20 AM - edited 03-14-2019 06:15 PM
Hello
A client is asking me to find a monitor to display different CUIC dashboards for live informations.
I'm just wondering which kind of monitors should I look for, is there a specific one or just any standard existing monitors out there will do the job ? If it's a normal one I guess I should use it with a PC
Solved! Go to Solution.
06-19-2018 08:28 AM
Hi there
You can get the CUIC Dashboard in a PC and get it extended to the LCD monitor with live metrics. That should be very easy and convenient.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-19-2018 08:28 AM
Hi there
Hope this helps!
Cheers
Rath!
06-19-2018 08:33 AM
Thank you sir, I thought that there is a special setup to integrate with CUIC
Thanks again
