Nuance ASR and TTS logs
ram
I was debugging a sample speech application in UCCX 8.5. Where do the MRCP logs recorded in Naunce servers?
thanks for the help
Ram
anchoudh
Level 9
Level 9
Hi Ram,
Vocalizer engine logs integrated in NSS logs;  the NSS logging mechanisms now integrate the logs of all the underneath engines including: NR9 and Vocalizer.
  • The same Nuance Session Identifier is used across all NSS components (NR9, Vocalizer,     NSS) involved in a specific MRCP session.  That session identifier can then be used to map all the logs, alarms, call logs of a specific MRCP session.
  • NR9, Vocalizer and NSS error logs and diagnostic logs are all saved in the NSS log files.
  • NR9, Vocalizer and NSS severe errors are all reported in the same location (i.e. Management Station if available, NSS log files).
  • NR9, Vocalizer and NSS event logs are saved in one single call log file per MRCP session.
Reference:
ftp://ftp.comptek.ru/pub/Nuance/NSS/NSS-5.1-0-Release-Notes.html
In order to enable tracing in UCCX for MRCP ASR\TTS, go to UCCX servicability->Tracing->Engine->Subsystems and enable them. You will see these logs under MCVD folder.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
5 Replies 5
anchoudh
Level 9
Level 9
Hi Ram,
Reference:
Hope it helps.
Anand
Gergely Szabo
check under Nuance\Speech Server 5.0\server\logs
most like you need log.txt and nss.log
G.
Thank you that helped. I could able to find the logs and find the problem.
Hi Ram,
Glad to know that :-).
Please don't forget to rate the helpful posts by clicking on the stars below the right answer and also mark it as answered.
Anand
what was your problem and what logs did you actually use?
G.
