09-26-2008 06:08 AM - edited 03-14-2019 02:57 AM
We found that the side A and side B databases are not in sync. t_call_type_half_hour table in Side B's HDS & logger databases is having 7 calls less than in side B. Can I bring them using ICMDBA or do I need to manually update this table on side A by inserting the rows? Does it mean that there may possibility of other tables also not in sync?
09-26-2008 06:12 AM
First verify the issue is on both loggers, if so and the retention period is not set differently on the system, bring up ICMDBA, highlight the DB with the most records and select synch, HDS should get fix right afterwards by normal replication processes.
Riccardo
10-05-2008 10:59 PM
I would also suggest you check the time settings on both servers, as they may be out of sync.
C.
