simple UCCX script for IVR,Welcome message then press 1 and press 2
debasish rout
Dear Experts;
I have uccx 10.5.
I want to write a simple IVR script as below.
Step-1- Welcome message.with press 1 for Sales and Press 2 for Marketing
step-2   User Press 1 then transfer the call to Sales Skill Group.
Step-3  User press 2 then transfer the call to  Marketing Skill group.
My doubt is how to accept when user press 1 and match the value and then transfer the call to that skill group.
Really appreciate any link or script for this.
Debashis
Hi sir,
From the Media Palette you can pick "Menu".
There you can have a prompt, filter for keypresses and do actions depending on that keypress the user does.
/BR MG
martyn.rees
Level 4
Level 4
Have you had a look at the sample script repository? You can grab it from here if not. http://www.cisco.com/c/en/us/support/customer-collaboration/unified-contact-center-express/products-implementation-design-guides-list.html
It is listed under the 9.0.2 section (don't worry still applies for 10.x) and provides a long list of sample scripts including explanations.
Dear Martyn;
Thanks a lot that was very nice and valuable information.
just want to ask which palette i have to use to save the value 1 or 2 when user press 1 or 2.
I know using Menu we can create different Menu option.
After user press 1 it will go SALES skill group and if press 2 Go MARKETING Skill group.
Appreciate if you can help me in this regard.
Debashis
Hi sir,
/BR MG
Dear MG;
Thanks for your reply.
I got it now.
I am creating the same.
Thanks a lot.
