Statistics for Finesse Silent Monitoring
GaryMB119
Is there a way to gather statistics for When and by User, who is using the Silent Monitoring function in UCCX??
We need to help develop policies for when and under what circumstances this feature can and will be used by supervisors.
Thanks./gb
Anthony Holloway
Sorry, not that I've ever seen, nor could I even think of how this would be possible. My only thought, which I cannot help you with, just point you down the path, is to replace the built=in monitor functionality with your own custom gadget, and then make your gadget do the auditing of who/when/where/why/etc.
I ask, because it appears as if it was available in 10.5??
Did they remove the report???
[cid:image001.png@01D58B3F.56A0D8C0]
Were you trying to attach an image? If so, it seems to have failed.
A report you say? In 10.5 you say? Hmmm....checking...
EDIT: Oh are you talking about the Remote Monitoring Detail Report?  If so, that was something totally different, and yes, that went away.  That was a feature where you configure a trigger / app / script and Supervisors call into the trigger, enter a CSQ ID, and then monitor the next call to an Agent in that CSQ.
