05-09-2011 12:37 AM - edited 03-14-2019 07:52 AM
05-12-2011 12:02 PM
Hello Muzammel.
What is your local language and what languages do you have checked via AppAdmin > System Languages Configuration?
The UCCX system prompts are recorded in the default system language, usually English.
If you are unable to locate system prompts in your desired language you will have to re-record new prompts and upload them.
Then I would suggest you have a menu step inserted into the script that would give the callers the option to choose which
language.
Be apprised that this would entail having either a menu step in the existing script, which had properties configured to route
to language branch trees, within the same script w\ the various recored language prompts, or to entirely different scripts, that played the recorded prompts, in thereqeusted language of choice.
B.
05-14-2011 08:16 PM
Hi Berpicke,
Thank you for your suggestion. Our local language is Bengali and by this language is not listed in uccx. We want to make our scripts so that customer will have two options for languge selection; one for Bengali and two for English.
I have recorded all reqired prompts for Bengali. Now I need help in below areas:
(1). What the UCCX coniguration steps needed for this.
(2). Where (in which folder) I will upload Bengali media (system+user).
(3) What is the scripts steps so that I can use this language.
Thanks & Regards,
Muzammel
