System resourses detection????
Neal haas
Level 3
Level 3
I have a UCCX with many queue's and many different options.
I have a question, I want to see if all of the queue's are equal to 300, I want to start provideing a heavy call volume message.
how do I do this?
Thank you
6 Replies 6
Gergely Szabo
Hi, you can use the Get Reporting Statistic step to take the number of contacts waiting at CSQ and if it reaches a threshold, you can play a prompt.
G.
So are the fields in Get Reporting Statistic.
OBJECT: Overall IPCC Exxpress
Field: CSQ's
Row Identifier: Blank
This one is new to me.
Typically folks are looking at a Particular CSQ here..so the
Report Object would be CSQ IPCC Express
the Field is what Statistic you are looking for (perhaps Current Wait Duration..this is in seconds)
Row ID = the CSQ Name "CSQ" or String Variable that is assigned a value of the csq name sCSQiD = "CSQ"
the Result Statistic is an INT(int) Type you need to define in the Variable Pane of the CCX Editor.
so if(iResultStatistic >= 300)
          playMsg
     else
          dontPlayMsg
I am trying to get a way to get all of the CSQ's in the system at 1 time. I think that I have about 23 CSQ's in the system now.
So as was stated, Overall IPCC Express, whatever field you are trying to collect which normally returns an Integer value..refer to
Cisco Unified Contact Center Express Scripting and Development Series: Volume 2 page 212
I found what was needed.
Field: Contacts Waiting
Contact:Blank
Thanks for the pointers!
