Bookmark
Subscribe
693
tried to display dynamic string variable in Cisco finesse with Set Enterprise call info UCCX editor
arif58812
hello
i need your expert solution,
i have set up one variable in UCCX  editor which populated with names of the caller dynamically, and i wanted to show this information to agent in finesse. i  setup the set enterprise call info and add that variable in value option " customer_name" and assigning into call.perpheralvariable7. when i debug i can see the name  already  captured in the variable "customer_name"
but cannot see any value in the finesse agent in call variable 7  .
BTW  the variable customer names are stored in the XML document  and it mapped from the incoming call number.
can you please give me an indication how can i show this information to agent in finesse
david.macias
Login to Finesse admin and see what your layout looks like. You can assign variables to display to this layout.
david
Hi David
thanks for your reply. i made the layout following the cisco documents. https://www.cisco.com/c/en/us/support/docs/contact-center/unified-contact-center-express/213873-configure-uccx-custom-call-variable-layo.html
but still no value value showing up ,  only this showing up when i set up a Static value.
Start posting screenshots of your work. That's going to be the only way to get to the bottom of this.
david
