05-10-2016 01:57 AM - edited 03-14-2019 04:05 PM
hi
i install a new UCCE 11.01 (CVP , ICM , CUCM , GW2901)
i add a new script in the ICM , when i try to send the call with RunExternalScript in the CVP server , GS,Server,V its didnt work , the call disconnect.
the VXML serve configure on the CVP server.
i need help to resolved this issue (if you can to shre script for the ICM that make run exteranl script it will be graet )
Best regards
Yossi Dabah
05-11-2016 05:58 AM
Please do the following,
1. You have to cycle your VRU PG for changes done on microapp to take effect.
Please do exit_opc on your VRU PG.
2. when you defined something on user.microapp.ToExtVXML , you have to define array index(what place on array you want to send the data ). e.g. 0,1,2,3
3. application=HelloWorld should be in ""
i would recommend you to start reading CVP design and configuration guide.
05-16-2016 01:38 PM
Thanks a lot for your help its work , i configure the
user.microapp.ToExtVXML as array.
Yossi
