UCCE ICM Routing Script Question
iFhonKMUTNB
Refer some discussed UCCE can get The position in queue of the new call will be SkillGroup.<variable>.RouterCallsQNow + 1. But we had used Dynamic Precision Queue in Routing. we tried to use Dynamic Formula following in UCCE Scripting and Media routing guide but we found issue in case if we need to get the position in queue and send variable to CVP for announcement, Example Call.Peripheral7 = PQ.{Call.user.pq}.CallsInQ. So we got the problem show in below, Please find artifact in attachment
Unrecognized character: {
Do you want to ignore this error for now ?
My question is any one can suggest us How to get the position call in queue and set into parameter send to run microapp (CVP)??
5 Replies 5
shidas
If we validate the custom function the validation is successful. But node validation is failing.
This seems to be a product defect. We will raise a defect.
Shikhar
Hi Shikhar,
Agree with you, I already raise to Cisco TAC but they just reply that is custom they not support.
svs
UCCE do not support position in queue feature. More information can be seen in earlier discussions at the below thread
https://communities.cisco.com/message/81505#81505
ptindall
If you need visibility into calls queuing, provided you're using CVP, this is the workaround quite a few people have been using.  https://cisco.box.com/v/shadow
Hi Paul,
Thank you for suggested, I will try following this and will let's you know if we got any problem.
