UCCE Predictive Dialer Call flow - Query
Dear Experts,
Kindly request your support/guidelines to understand the dialer call flow for a predictive dialing. I tried to collect the logs as per the call flow as below; please let me know I am in thr right direction or not. Also I have a query over here that the dialer is sending call to the VG by prefix 89. But I am unable to figure out from where it is getting this 89.?? It will be highly appreciate if you guys can guide me where to check this.
  • The call will delivered to call manager only when a valid voice type recognized by dialer and then the dialer initiate call transfer to the agent via CUCM
  • The prefix 89 before the dialer dialing via VG, where I can find out this configuration?
  • My campaign prefix is 111 which I can see as CLI in the remote side.
 Platform :
UCCE - 8.5
SIP Dialer
UCM - 8.5
Dialing mode - Predictive
  1. Import is scheduled and the campaign starts. Records are delivered to Dialer.
  1. The dialer process continually monitors peripheralskill group statistics from the CTI server for an available agent. Concurrently the campaign manager monitors the database for customer records and forwards active records to the dialer. When the dialer identifies an available agent for use in an outbound campaign, it sends a route request to the MR PIM.
  2. The MR PIM forwards the route request to the router.
  3. The Unified ICM/CCE/CCH CallRouter executes a routing script, selects an available agent, reserves that agent, and then returns a routing label (phone extension) identifying the reserved agent.
  4. Media RoutingPIM notifiesthe Dialer that the agent is available. The dialer then sends an agent reservation request to the Agent PG. The Agent PG generates a virtual agent reservation call to the agent desktop, and automatically places that virtual reservation call into answered state and then on hold.
Agent PIM Logs:
2:41:560 PG5B-pim1 Trace: CSTA SERVICE INITIATED, MonitoredPhone::ServiceInitiated: (Monitored Phone)
                 CallID     = 2131644722  DeviceID = 8386  DeviceType = Static
                 LocalState = INITIATE
                 Cause      = EC_NONE
14:22:41:560 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_INSIDE(2) ) for line 0 on instrument 8386
14:22:41:560 PG5B-pim1 Trace: CSTA ORIGINATED, MonitoredPhone::Originated: (Monitored Phone)
                 ConnectionID   = (2131644722,8386) DeviceType = Static   à 8386 is the virtual number assigned to dialer port 086
                 Calling Device = 8386      Type       = DEVICE_IDENTIFIER
                 Called  Device = 8463      Type       = AGENT_DEVICE_IDENTIFIER  à 8486 is the extension of agent
                 Local State    = 1
                 Cause          = -1
14:22:41:560 PG5B-pim1 Trace: CSTA ORIGINATED, MonitoredPhone::Originated: SENT TO OPC
                 Local State    = 1
                 Cause          = -1
14:22:41:560 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_INSIDE(2) ) for line 0 on instrument 8463
14:22:41:560 PG5B-pim1 Trace: MatchPendingCall (DeskLinkCall) : Inst: N8463 CreatedByPreCall: T PeriphCID: -1 RouterCallKey=(152315/124821)
14:22:41:560 PG5B-pim1 Trace: CancelAgentTimer: type = agentTimerReserved
14:22:41:560 PG5B-pim1 Trace: Offered matched PreCall for CID: 2131644722 Ext: 8463 SecondsPending: 0
14:22:41:560 PG5B-pim1 Trace: FreePreRoutedCall: Head Inst: N8463 CreatedByPreCall: T PeriphCID: -1 Queue Count: 0 RouterCallKey=(152315/124821)
14:22:41:560 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_INBOUND_ACD(0) ) for line 0 on instrument 8463
14:22:41:560 PG5B-pim1 Trace: CSTA DELIVERED, TelephonyDriver::Offered: SENT TO OPC
                 Alerting    =
                 Calling     = 8386
                 Called      = 8463
                 Redirection =
                 Cause       = EC_NONE
14:22:41:560 PG5B-pim1 Trace: CSTA DELIVERED, TelephonyDriver::Delivered: SENT TO OPC
                 Alerting    = 8463
                 Calling     = 8386
                 Called      = 8463
                 Redirection =
                 LocalState  = ALERTING
                 Cause       = EC_NONE
14:22:41:560 PG5B-pim1 Trace: ScheduleAgentTimer: type = agentTImerRingTimeout, seconds = -1, callback = 2131644722
14:22:41:560 PG5B-pim1 Trace: Checking for agent whisper enabled. Ext=8463 CallID=2131644722 AW enabled=0 ReqEnbld:0 ReqSt=0
14:22:41:561 PG5B-pim1 Trace: Checking for RNA Requery. Ext=8463 CallID=2131644722 RNA=0 Qtime=4 ReqEnbld:0 DNID:0 ReqSt:0
14:22:41:561 PG5B-pim1 Trace: CancelAgentTimer: type = agentTImerRingTimeout
14:22:41:561 PG5B-pim1 Trace: CSTA ESTABLISHED, TelephonyDriver::Established: SENT TO OPC
                 CallID      = 2131644722  DeviceID = 8463  DeviceType = Static
                 Answering   = 8463
                 Calling     = 8386
                 Called      = 8463
                 Redirection =
                 LocalState  = CONNECT
                 Cause       = EC_NONE
14:22:41:561 PG5B-pim1 Trace: NeedPlayAgentGreeting: GREET= CustID=-1
14:22:41:561 PG5B-pim1 Trace: DeskLinkAgent::SetPendingPrevalentAgentState(Agent 21133 ext 8463) new pending agent state AS_TALKING
14:22:41:561 PG5B-pim1 Trace: SetPrevalentAgentState: (Agent 21133 ext 8463) newAgentState=AS_TALKING(4) reasoncode=0 stateDuration=0 currentLineHandle=0 lineType=LT_INBOUND_ACD(0) newLineState=LS_UNKNOWN(5) devString=
14:22:41:561 PG5B-pim1 Trace: SetPrevalentState: newState=AS_TALKING(4) reasoncode=0
14:22:41:561 PG5B-pim1 Trace: UpdateSkillGroupStates: (Agent 21133 ext 8463) reasoncode=0 stateDuration=0 currentLineHandle=0 currentLineType=LT_INBOUND_ACD(0) newLineState=LS_UNKNOWN(5) devString=
14:22:41:561 PG5B-pim1 Trace: DeskLinkAgent::UpdateSkillGroupStates:ReserveAgentStateUpdate: Peripheral Number = 21133 Extension Number String = 8463
Skill Group Number = 7740 Line Handle = 0 Agent State = AS_TALKING
Duration Current State = 0 reason code = 0 networkTargetID = 0
14:22:41:561 PG5B-pim1 Trace: DeskLinkAgent::UpdateLineStates:ReserveAgentLineUpdate: Line Handle = 0 Line Type = LT_INBOUND_ACD
New Line State = LS_TALKING  State Duration = 0  Skill Group Number = 7740
14:22:41:561 PG5B-pim1 Trace: CSTA HELD, Held: SENT TO OPC
                 HoldingDevice = 8463
                 LocalState    = HOLD
                 Cause         = EC_NONE
14:22:41:561 PG5B-pim1 Trace: SetPrevalentAgentState: (Agent 21133 ext 8463) newAgentState=AS_HOLD(10) reasoncode=0 stateDuration=0 currentLineHandle=0 lineType=LT_INBOUND_ACD(0) newLineState=LS_UNKNOWN(5) devString=
14:22:41:561 PG5B-pim1 Trace: SetPrevalentState: newState=AS_HOLD(10) reasoncode=0
Above agent is reserved by virtual call by Dailer to the agent and it places as hold until the dialer get a valid voice contact.
  1. Dialer signals the gateway to place outbound calls to the customers by using a SIP INVITE.
  2. The Gateway places outbound calls to the customers, and Dialer is notified the Gateway is trying.
BaDialer Logs:
Allocate port: 059, owner: DIALER_PREDICTIVE
14:25:45:548 dialer-baDialer Trace: (CPORT)        SetState, port: 059, state: GET_RECORD
14:25:45:548 dialer-baDialer Trace: (PM)
14:25:45:548 dialer-baDialer Trace: (CUST)           SetCallResult, id: 4523 in DL_5050_5047, skill: 6835, result: 1 [DIAL_RESERVED], now: [Wed Jan 10 14:25:45 2018], callback: [Wed Jan 10 14:24:31 2018]
14:25:45:548 dialer-baDialer Trace: (CM)              Send customer: 07706527278 record id: 4523, in DL_5050_5047 to port: 059
14:25:45:548 dialer-baDialer Trace: (PDD)             Record available event, port: 059, phone: 07706527278
14:25:45:548 dialer-baDialer Trace: (CPORT)        SetState, port: 059, state: PORT_DEVICE_ATTRIB
14:25:45:548 dialer-baDialer Trace: (SIP)               Dial, port: 059, phone 8907706527278, lDialTimeoutSec 64
                                CPA Parameters: AP = 2500, MinSP = 608, MinVSpeech = 112, MaxTA= 3000, MaxTone = 30000
14:25:45:548 dialer-baDialer Trace: (PDD)             ---> Dialing, phone: [8907706527278], port: 059, ring timeout: 64, state: PORT_DEVICE_ATTRIB  à here as you see the number is prefix with 89 ????
14:25:45:548 dialer-baDialer Trace: (CPORT)        SetState, port: 059, state: DIAL_CUSTOMER
14:25:45:660 dialer-baDialer Trace: (SIPThrottle)               Dial, port: 059, phone 8907706527278
14:25:45:660 dialer-baDialer Trace: DialerAppDialogSet - SIP port: 059, station: 8359, state: SIP_LINESTATE_IDLE
14:25:45:660 dialer-baDialer Trace: initialRequest - SipReq:  INVITE 8907706527278@10.200.128.131 cid=ca0efc5d-a420d426-4e26554f-8c4eb76e tid=1034da2f073aba3c cseq=INVITE contact=8359 / 1 from(tu)
14:25:45:674 dialer-baDialer Trace: CSipUATelephonyServer::HandleKeepAliveTimer
  1. Call Progress Analysis is done at the Gateway. Voice is detected, and Dialer is notified.
14:26:04:317 dialer-baDialer Trace: (DD)               Softphone connection event, phone: 8907706527278, result: VOICE, port: 059, state: DIAL_CUSTOMER,
14:26:04:317 dialer-baDialer Trace: (CUST)           SetCallResult, id: 4523 in DL_5050_5047, skill: 6835, result: 10 [VOICE], now: [Wed Jan 10 14:26:04 2018], callback: [Wed Jan 10 14:24:31 2018]
14:26:04:317 dialer-baDialer Trace: (PDD)             Received Telephony Event port: 059, connection state: 20
14:26:04:317 dialer-baDialer Trace: (CPORT)        SetState, port: 086, state: AGENT_RESERVE
14:26:04:317 dialer-baDialer Trace: (CPORT)        SetState, port: 059, state: TRANSFER
14:26:04:317 dialer-baDialer Trace: (PDD)             Transferring Customer port: 059, to Agent port: 086, Agent Id: 6684, Connection id 8386, Customer: 07706527278, Dial Id: 4523
14:26:04:317 dialer-baDialer Trace: (SIP)               Transfer, port: 059, phone 8463
14:26:04:317 dialer-baDialer Trace: (CPORT)        Duplicate SetState, port: 059, state: TRANSFER
14:26:04:323 dialer-baDialer Trace: SipISH-onReferAccepted:
                                SipReq:  NOTIFY 8359@10.200.128.158:58800 cid=ca0efc5d-a420d426-4e26554f-8c4eb76e tid=AB77EBB2018 cseq=NOTIFY contact=8907706527278@10.200.128.131:5060 / 103 from(wire)
                                SIP port: 059, station: 8359, state: SIP_LINESTATE_REFER_SENT
14:26:04:323 dialer-baDialer Trace: SipCSH::onUpdatePending:
14:26:04:364 dialer-baDialer Trace: (CLMGR_SIP)              Call delivered (agent), port: 059, id: 104253477
14:26:04:366 dialer-baDialer Trace: (PDD)             Begin Call event port: 059, Connection id: 104253477 state: TRANSFER
14:26:04:366 dialer-baDialer Trace: (CLMGR)      CTI SetCallData request, invoke: 215273, port: 059, call: 104253477
                type: 34, disposition: 23, ani: [07706527278]
                campaign: 5050 [CrossnetData_Sub_D1], query rule: 5047, acc#: []
                status: [CO], response: [CPA_Voice], list id: [4523], time zone: [+00180]
                CallerEnteredDigits: [NULL], customer name: [,], skill target id: , CallOriginated: [D]
14:26:04:366 dialer-baDialer Trace: (PDD)             Call Delivered event port: 059, Connection id: 104253477 state: TRANSFER, Customer: 07706527278, DialId: 4523
14:26:04:366 dialer-baDialer Trace: (CPORT)        SetState, port: 059, state: ANSWER_TRANSFER
14:26:04:366 dialer-baDialer Trace: (PDD)             Added Call id: 104253477 to desktop monitor; dialer auto answer: YES
14:26:04:368 dialer-baDialer Trace: SipCSH::onUpdateActive:
                                SipReq:  NOTIFY 8359@10.200.128.158:58800 cid=ca0efc5d-a420d426-4e26554f-8c4eb76e tid=AB77EBF576 cseq=NOTIFY contact=8907706527278@10.200.128.131:5060 / 104 from(wire)
9             The Dialer asks the voice Gateway to transfer the answered outbound call to the reserved agent by its agent extension.
                And release the dialer port reserved for this call.
14:26:07:395 dialer-baDialer Trace: (CLMGR_SIP)              Call established, port: 059, id: 104253477, ext: [8463], agent: [21133] calling device id: [8907706527278]
14:26:07:403 dialer-baDialer Trace: SipCSH::onTerminated:
                                SipReq:  NOTIFY 8359@10.200.128.158:58800 cid=ca0efc5d-a420d426-4e26554f-8c4eb76e tid=AB77ED1393 cseq=NOTIFY contact=8907706527278@10.200.128.131:5060 / 105 from(wire)
                                SIP port: 059, station: 8359, state: SIP_LINESTATE_REFER_ACTIVE
14:26:07:403 dialer-baDialer Trace: SIP NOTIFY: SipFrag statusCode = 200
14:26:07:404 dialer-baDialer Trace: (DD)               Softphone transfer complete event, phone: 8907706527278, result: VOICE, port: 059, state: ANSWER_TRANSFER,
14:26:07:404 dialer-baDialer Trace: (PDD)             Received Telephony Event port: 059, connection state: 20
14:26:07:404 dialer-baDialer Trace: (PDD)             ***End call event port: 059, state: ANSWER_TRANSFER***
14:26:07:404 dialer-baDialer Trace: (PDR)             Release agent request, port: 086, state: AGENT_RESERVE
14:26:07:404 dialer-baDialer Trace: (PDR)             End port: 086
14:26:07:404 dialer-baDialer Trace: (CLMGR)      CTI ClearConnection request, invoke: 215313, port: 086, call: 2131644722, instrument: [8463]
14:26:07:404 dialer-baDialer Trace: CCallManager::RemoveCall -> call: 2131644722
14:26:07:404 dialer-baDialer Trace: (SIP)               Hangup, port: 086   à Release the port
14:26:07:404 dialer-baDialer Trace: (PM)
Release port: 086, state: [AGENT_RESERVE]
14:26:07:404 dialer-baDialer Trace: (CPORT)        SetState, port: 086, m_ReservationCallTime: 205875, state: IDLE
14:26:07:404 dialer-baDialer Trace: (SIP)               Hangup, port: 059
Release port: 059, state: [ANSWER_TRANSFER]
14:26:07:404 dialer-baDialer Trace: (CPORT)        SetState, port: 059, m_CustomerCallTime: 21859, state: IDLE
14:26:07:405 dialer-baDialer Trace: Info:: HandleByeMsg - SIP port: 086, station: 8386, state: SIP_LINESTATE_IDLE
14:26:07:405 dialer-baDialer Trace: Info:: HandleByeMsg - SIP port: 059, station: 8359, state: SIP_LINESTATE_IDLE
14:26:07:409 dialer-baDialer Trace: SipISH-onTerminated:0
                                SipReq:  BYE 8359@10.200.128.158:58800 cid=ca0efc5d-a420d426-4e26554f-8c4eb76e tid=AB77ED2215E cseq=BYE / 106 from(wire)
14:26:07:409 dialer-baDialer Trace: SIP port: 059, station: 8359, state: SIP_LINESTATE_IDLE
14:26:07:409 dialer-baDialer Trace: ~DialerAppDialogSet - SIP port: 059, station: 8359, state: SIP_LINESTATE_IDLE
10           The Gateway directs the answered outbound calls to the agents through Unified CM, using agent extensions and Unified CM host address. The Dialer auto-answers the transferred call for the agent through the CTI server so that the voice path between the customer and the agent can be quickly established.
Call Manager Logs:
14:26:34.977 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 1242 from 10.200.128.131:[53909]:
[459252,NET]
INVITE sip:8463@10.100.100.124:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.128.131:5060;branch=z9hG4bKAB77EBC18A7
Remote-Party-ID: <sip:8907706527278@10.200.128.131>;party=calling;screen=no;privacy=off
From: <sip:8907706527278@10.200.128.131>;tag=8992C570-578
To: <sip:8463@10.100.100.124>
Date: Wed, 10 Jan 2018 11:26:34 GMT
Call-ID: F325332C-F52F11E7-887FC527-308E9096@10.200.128.131
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  90
Cisco-Guid: 3893022448-4113502695-2276508967-0814649494
User-Agent: Cisco-SIPGateway/IOS-15.2.3.T1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1515583594
Contact: <sip:8907706527278@10.200.128.131:5060>
Call-Info: <sip:10.200.128.131:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 60
Referred-By: sip:8359@10.200.128.158  à Initial customer dialed port station id
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 197
v=0
o=CiscoSystemsSIP-GW-UserAgent 2664 8700 IN IP4 10.200.128.131
s=SIP Call
c=IN IP4 10.200.128.131
t=0 0
m=audio 16722 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
|6,100,220,1.80581^10.200.128.131^*
14:26:34.978 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.200.128.131:[5060]:
[459253,NET]
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
14:26:35.011 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.200.128.131:[5060]:
[459254,NET]
SIP/2.0 180 Ringing
To: <sip:8463@10.100.100.124>;tag=194007~22b80be0-eca5-435c-9738-72cf1b024469-105462089
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: <sip:8463@10.100.100.124>
Remote-Party-ID: <sip:8463@10.100.100.124>;party=called;screen=yes;privacy=off
Contact: <sip:8463@10.100.100.124:5060>
Content-Length: 0
14:26:38.044 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.200.128.131:[5060]:
[459259,NET]
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
Content-Length: 160
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.100.100.124
s=SIP Call
c=IN IP4 10.200.128.120
t=0 0
m=audio 25704 RTP/AVP 0
a=ptime:20
|2,100,50,1.36038685^10.200.128.120^MTP_2
14:26:38.069 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 437 from 10.200.128.131:[53909]:
[459260,NET]
ACK sip:8463@10.100.100.124:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.128.131:5060;branch=z9hG4bKAB77ED0193F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
|6,100,220,1.80582^10.200.128.131^*
Agent PIM Logs:
14:26:04:356 PG5B-pim1 Trace: Delivered: CID=104253477 ConnDevID=8907706527278/1  AlertDevID=/0 CallingDev=8907706527278/0 CalledDev=8463/0 LastRedDev=/0 LocalConn=1 Cause=22OrgTrk=-1 OrgTrkGrp=-1 TermTrk=-1 TrmTrkGrp=-1UniqueID= 000000000036C8250649394A00000000 ANI=8907706527278 DevTgDevStr=8463
14:26:04:356 PG5B-pim1 Trace: GetAgentWhispePrimaryCallID: Unable to find PreRoutedCallPending 104253477
14:26:04:356 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_INSIDE(2) ) for line 1 on instrument 8463
14:26:04:356 PG5B-pim1 Trace: CSTA DELIVERED, TelephonyDriver::Offered: SENT TO OPC
                 CallID      = 104253477  DeviceID = 8907706527278  DeviceType = Dynamic
                 Alerting    =
                 Calling     = 8907706527278
                 Called      = 8463
                 Redirection =
                 Cause       = EC_NEW_CALL
14:26:04:356 PG5B-pim1 Trace: Delivered: CID=104253477 ConnDevID=8907706527278/1  AlertDevID=8463/0 CallingDev=8907706527278/0 CalledDev=8463/0 LastRedDev=/0 LocalConn=2 Cause=-1OrgTrk=-1 OrgTrkGrp=-1 TermTrk=-1 TrmTrkGrp=-1UniqueID= 000000000036C8250649394A00000000 DevTgDevStr=8463
14:26:04:356 PG5B-pim1 Trace: CSTA DELIVERED, TelephonyDriver::Delivered: SENT TO OPC
                 Alerting    = 8463
                 Called      = 8463
                 Redirection =
                 Cause       = EC_NONE
14:26:04:356 PG5B-pim1 Trace: ScheduleAgentTimer: type = agentTImerRingTimeout, seconds = -1, callback = 104253477
14:26:04:369 PG5B-pim1 Trace: TPCSTAAssociateDataMsg: Peripheral::ProcessCSTAThirdPartyServiceRequest InvokeID=0xf008b544 ExistingCall(CID=104253477,Dev=8907706527278,Type=Dynamic) AccountInfo= AuthorCode= CalledPartyDisposition=0,<UNKNOWN DISPOSITION>
14:26:04:369 PG5B-pim1 Trace: PRIVATE_DATA: AGID=21133 CorrData= WrapupData=ÿ CED=ÿ ANI=07706527278 UUIData=ÿ
14:26:07:386 PG5B-pim1 Trace: Established: CID=104253477 ConnDevID=8463/0  AnsDevID=8463/0 CallingDev=8907706527278/0 CalledDev=8463/0 LastRedDev=/0 LocalConn=3 Cause=-1OrgTrk=-1 OrgTrkGrp=-1 TermTrk=-1 TrmTrkGrp=-1UniqueID= 000000000036C8250649394A00000000 DevTgDevStr=8463
14:26:07:386 PG5B-pim1 Trace: Checking for agent whisper enabled. Ext=8463 CallID=104253477 AW enabled=0 ReqEnbld:0 ReqSt=0
14:26:07:386 PG5B-pim1 Trace: Checking for RNA Requery. Ext=8463 CallID=104253477 RNA=0 Qtime=4 ReqEnbld:0 DNID:0 ReqSt:0
14:26:07:386 PG5B-pim1 Trace: Established:: Line state and Agent state mismatch make the Line state to Talking
14:26:07:386 PG5B-pim1 Trace: CancelAgentTimer: type = agentTImerRingTimeout
14:26:07:386 PG5B-pim1 Trace: CSTA ESTABLISHED, TelephonyDriver::Established: SENT TO OPC
                 CallID      = 104253477  DeviceID = 8463  DeviceType = Static
                 Answering   = 8463
                 Called      = 8463
                 Redirection =
                 Cause       = EC_NONE
14:26:07:387 PG5B-pim1 Trace: NeedPlayAgentGreeting: GREET= CustID=-1
14:26:07:387 PG5B-pim1 Trace: DeskLinkAgent::SetPendingPrevalentAgentState(Agent 21133 ext 8463) new pending agent state AS_TALKING
14:26:07:387 PG5B-pim1 Trace: SetPrevalentAgentState: (Agent 21133 ext 8463) newAgentState=AS_TALKING(4) reasoncode=0 stateDuration=0 currentLineHandle=1 lineType=LT_INSIDE(2) newLineState=LS_UNKNOWN(5) devString=
14:26:07:387 PG5B-pim1 Trace: SetPrevalentState: newState=AS_TALKING(4) reasoncode=0
14:26:07:387 PG5B-pim1 Trace: UpdateSkillGroupStates: (Agent 21133 ext 8463) reasoncode=0 stateDuration=0 currentLineHandle=1 currentLineType=LT_INSIDE(2) newLineState=LS_UNKNOWN(5) devString=
14:26:07:387 PG5B-pim1 Trace: DeskLinkAgent::UpdateSkillGroupStates:ReserveAgentStateUpdate: Peripheral Number = 21133 Extension Number String = 8463
Skill Group Number = 7740 Line Handle = 1 Agent State = AS_TALKING
14:26:07:387 PG5B-pim1 Trace: DeskLinkAgent::UpdateLineStates:ReserveAgentLineUpdate: Line Handle = 1 Line Type = LT_INSIDE
14:26:07:396 PG5B-pim1 Trace: RTPStarted: CID=104253477, ConnDevID=8463/0, Addr=10.54.152.72:24938, Direction=IN, RtpType=Audio, BitRate=1, EchoCan=ON, PktSize=20, Payload=4 , UniqueID=000000000036C8250649394A00000000
14:26:07:405 PG5B-pim1 Trace: CSTAClearConnection: Peripheral::ProcessCSTAThirdPartyServiceRequest InvokeID=0xf008b545 Call(CID=2131644722,Dev=8463,Type=Static)
14:26:07:405 PG5B-pim1 Trace: PRIVATE_DATA: CompoundRequestType=Unknown CSTA Event Type SubjectDevice=8463
14:26:07:405 PG5B-pim1 Trace: DeskLinkAgent::IsWorkModeRequired: CID: 2131644722, no wrap-up required on Blended Agent Reservation Call
14:26:07:405 PG5B-pim1 Trace: CSTA CONNECTION CLEARED, TelephonyDriver::ConnectionCleared: SENT TO OPC
                 ReleasingDevice = 8463
                 LocalState      = NONE
                 Cause           = EC_NONE
14:26:07:406 PG5B-pim1 Trace: DeskLinkAgent::GetNumActiveACDCalls(Agent 21133 ext 8463) return 1
14:26:07:406 PG5B-pim1 Trace: DeskLinkAgent::IsWorkModeRequired: CID: 2131644722, no wrap-up required on Blended Agent Reservation Call
14:26:07:406 PG5B-pim1 Trace: SetPrevalentAgentState: (Agent 21133 ext 8463) newAgentState=AS_TALKING(4) reasoncode=0 stateDuration=0 currentLineHandle=0 lineType=LT_INBOUND_ACD(0) newLineState=LS_IDLE(3) devString=
14:26:07:406 PG5B-pim1 Trace: SetPrevalentState: newState=AS_TALKING(4) reasoncode=0
14:26:07:406 PG5B-pim1 Trace: UpdateSkillGroupStates: (Agent 21133 ext 8463) reasoncode=0 stateDuration=0 currentLineHandle=0 currentLineType=LT_INBOUND_ACD(0) newLineState=LS_IDLE(3) devString=
14:26:07:406 PG5B-pim1 Trace: DeskLinkAgent::UpdateSkillGroupStates:ReserveAgentStateUpdate: Peripheral Number = 21133 Extension Number String = 8463
14:26:07:406 PG5B-pim1 Trace: DeskLinkAgent::UpdateLineStates:ReserveAgentLineUpdate: Line Handle = 0 Line Type = LT_INBOUND_ACD
New Line State = LS_IDLE  State Duration = 0  Skill Group Number = 7740
14:26:07:406 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_UNKNOWN(3) ) for line 0 on instrument 8463
14:26:07:406 PG5B-pim1 Trace: CSTA CONNECTION CLEARED, MonitoredPhone::ConnectionCleared: (Monitored Phone)
                 ReleasingDevice = 8386
                 LocalState      = NONE
                 Cause           = EC_NONE
14:26:07:406 PG5B-pim1 Trace: JTAPILine::SetLineType( LT_UNKNOWN(3) ) for line 0 on instrument 8386
14:26:07:406 PG5B-pim1 Trace: CSTA CALL CLEARED, TelephonyDriver::CallCleared: SENT TO OPC
  DeviceType = Static       LocalState = NONE
                 Cause      = EC_NONE
14:26:07:406 PG5B-pim1 Trace: CSTAClearConnectionConfEvent: TPServices::CSTAClearConnectionConfEvent InvokeID=0xf008b545
14:26:07:430 PG5B-pim1 Trace: RTPStarted: CID=104253477, ConnDevID=8463/0, Addr=10.200.128.120:25706, Direction=OUT, RtpType=Audio, BitRate=1, EchoCan=ON, PktSize=20, Payload=4 , UniqueID=000000000036C8250649394A00000000
11  call cleared after the finishing the successful contact with agent and customer Agent PIM.
PIM Logs:
14:28:46:053 PG5B-pim1 Trace: RTPStopped: CID=104253477, ConnDevID=8463/0, Addr=10.54.152.72:24938, Direction=IN, UniqueID=000000000036C8250649394A00000000
14:28:46:053 PG5B-pim1 Trace: RTPStopped: CID=104253477, ConnDevID=8463/0, Addr=10.200.128.120:25706, Direction=OUT, UniqueID=000000000036C8250649394A00000000
14:28:46:053 PG5B-pim1 Trace: ConnectionCleared: CID=104253477 ConnDevID=8463/0 ReleasingDev=8463/0 LocalConn=-1 Cause=-1UniqueID=000000000036C8250649394A00000000 DevTgDevStr=8463
14:28:46:053 PG5B-pim1 Trace: DeskLinkAgent::GetNumActiveACDCalls(Agent 21133 ext 8463) return 1
14:28:46:053 PG5B-pim1 Trace: CSTA CONNECTION CLEARED, TelephonyDriver::ConnectionCleared: SENT TO OPC
                 LocalState      = NONE
                 Cause           = EC_NONE
BA Dialer Logs:
14:28:46:061 dialer-baDialer Trace: (CLMGR)      Call cleared, port: 059, id: 104253477
14:28:46:063 dialer-baDialer Trace: (DM)              Customer call cleared, connection id: 104253477, customer: 07706527278, Dial Id: 4523, PortId: 59
14:28:46:063 dialer-baDialer Trace: (CLMGR)      End call, port: 059, id: 104253477
14:28:46:066 dialer-baDialer Trace: (DM)              #####Customer call ended, connection id: 104253477, customer: 07706527278, dialId: 4523####
14:28:46:066 dialer-baDialer Trace: (DM)              Close customer record: 4523 in DL_5050_5047
14:28:46:066 dialer-baDialer Trace: (CM)              Close record request, customer: 07706527278, Dial Id: 4523 in DL_5050_5047, result: 10 [VOICE]
14:28:46:066 dialer-baDialer Trace: (CUST)           Record sent to campaign manager, id: 4523 in DL_5050_5047, skill: 6835, result: 10 [VOICE]
Call Manager Logs:
14:29:16.689 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 569 from 10.200.128.131:[53909]:
[459702,NET]
BYE sip:8463@10.100.100.124:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.128.131:5060;branch=z9hG4bKAB781FB448
Max-Forwards: 70
Timestamp: 1515583756
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=7930,OS=1268800,PR=7932,OR=1269120,PL=0,JI=3,LA=0,DU=158
Content-Length: 0
|6,100,220,1.80684^10.200.128.131^*
Shalid Chalil
Hi there,
Check:
if have you configured under
Campaign General tab --> Campaign Prefix digit
or
In Dialer Settings --> General Telephony section
or
in registry at here on the dialer(Keys ends with name prefix):
HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\ICM\<instance name>\Dialer
5 Replies 5
UCCE 8.5 SIP Dialer is not supported with SIP Trunk, this is why you have the E1's.
89 is a prefix we added to the SIP response message on the CUBE so that the calls will be matched to dial-peer voice 100 to use the E1 interface
P.S: 88 prefix is used for Fanoos Outbound calls.
Good Luck.
Amer
Thanks Amer..
but the below command, should remove the 89 from the message , right?
response 180 sip-header From modify "<sip:89(07.*)@10.200.128.130>" "<sip:\1@10.200.128.130>"
so my initial question is where the dialer or the message request is getting 89 with the contacts. we are uploading only 077XXXXXXXX.
appreciated if you can shed some light on it?
Shalid
in that case you need to check the dialer configuration on UCCE, can you share some screenshots as i am sure it is there somewhere.
Amer
Hi there,
Check:
or
or
Many thanks Chintan.
I missed this at first place. i found it in dialer settings under general telephony section.
Shalid
