07-27-2011
03:21 PM
- last edited on
03-25-2019
07:18 PM
by
ciscomoderator
I have a client who is using UCCX to run a small help desk environment. I have their helpdesk script configured already where if there are no agents logged in when a call enters the queue it emails the management and gives them a heads up. The client would like the UCCX to place a call to certain managers if there are no agents online and play a propmt informing them of the situation and asking if they would like to take the call. I have been playing with this on and off for a few days and just cannot get it to act right.
Has anyone out there done this before? It sounds like something that would be quite common but I cannot seem to get it to work correctly.
Any help would be greatly appreciated!
Thanks!
Dan
Solved! Go to Solution.
07-27-2011 03:59 PM
Maybe try checking the MIVR logs for a reason for the outbound call to drop when it goes through; may be a codec mismatch or something else external to UCCX.
Also try using a seperate call control group for the outbound contact.
In fact, I think last time I did this I didn't specify a 'media' group on the place call step, so as soon as you try to play a prompt it falls on it's face, and in the MIVR logs you get a licensing error - someting along the lines of using an unsupported step perhaps.
Aaron
07-27-2011 03:32 PM
Not really sure how far you've got, but some pointers:
- You'll use a place call step to call out to the manager, and assign the resulting contact to a contact variable.
- When you want to play prompts/menus to the manager, ensure you select the contact variable above instead of the default
- Before you transfer the original caller to the manager, you'll want to 'terminate' the contact created above
- You'll want to put
- You will also want to set a 'on exception' step for a 'contactinactiveexception' such that if the original caller hangs up, you can terminate the outgoing manager call and tidy things up
If you can advise how far you've got, and where things are failing, someone will probably advise further.
Aaron
Please rate helpful posts..
07-27-2011 03:50 PM
Thank you for the informative response. Please see snippet below. I am working this in a lab environment just to get it hammered out right now. I place the Triggering Contact on hold and then place a Call to Manager1Phone which is assigned to Manager1Contact. The call completes but as soon as I pick up the phone the line hangs up without playing the prompt and the client in the queue gets the "we are experiencing system errors" message.
07-27-2011 03:59 PM
Aaron
08-05-2011 12:29 PM
Mismatch...DOH
