08-21-2012 07:35 PM - edited 03-14-2019 10:23 AM
Hello there,
WE are doing upgrade from UCCX 7.0 to UCCX 8.5 for one of our client.
During upgrade we need various testing. The question is can we also install CAD version 8.0 on agent desktop machine which is currently running CAD 7.0?
Both CAD Versions 7.0 and 8.0 on agent machine simultaneously ? ? ? in UCCX 7.0 environment.
08-21-2012 07:36 PM
If possible please give me the reference. thanks
08-21-2012 07:49 PM
Hi Hafiz,
You can not have two versions of CAD on the same box, UCCX will not allow you to install the CAD for the second time, it will either allow for the CAD upgrade or ask you to uninstall the existing CAD and reinstall the new version of it.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
08-21-2012 08:51 PM
thanks, Just a double confirmation that on Agent PC, he cant have two CADs ! right?? thanks again
08-21-2012 08:53 PM
Hi Hafiz,
Yes, on a Single PC you can not run two versions of CAD instances.
Anand
Pls rate helpful posts !!
