UCCX script compatibility between 7.0 and 10.6
Melany Nolan
hi, is there any compatibility issue between the two versions?
i got most of the 7.0 scripts running well on 10.6. only two of them have issues, when i choose these scripts in the application, it prompts below error:
"An error orrcurred when loading the Script SCRIPT[xxx.aef]. Please check log for more details.
I tried to open these scripts in the UCCX script editor, they cannot be opened and have below error:
"Failed to load script file; com.cisco.script.ScriptIOException: Failed to load script: C:\xxx.aef; nested exception is:
com.cisco.io.StreamCorruptedException: invalid type code: 04; unable to load expression; ensure all custom classes are available; nested exception is:
java.io.StreamCorruptedException: invalid type code: 04
anyone has idea on it?
thank you.
11 Replies 11
Aaron Harrison
Post up the full log, you may be missing some important information.
Do you still  have the 7.x server available?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yes, 7.x server is still available, what log shall I need ?
From your 10.x editor that you are loading the script into, post up your MEDT logs from the client. They may tell you what specific step is an issue.
I asked about v7, as if you have it you can still get the 7.x editor. That allows you to open the script, check them for any 'custom' steps, or (in response to what we see in the MEDT logs) you can remove steps, then open the fixed script in 10.x and re-add the steps as needed. It depends what we see in the logs...
Aaron
thanks, here is the MEDT logs, seems like not related to steps?
5564: Mar 27 10:06:24.824 CST %MEDT-DESKTOP-7-UNK:Open script as user requests from menu bar or task bar
5565: Mar 27 10:06:31.152 CST %MEDT-DESKTOP-7-UNK:Opening script C:\test.aef
5566: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-UNABLE_LOAD_SCRIPT:Unable to load script: Script=C:\test.aef,Exception=com.cisco.io.StreamCorruptedException: invalid type code: 04; unable to load expression; ensure all custom classes are available; nested exception is:
5567: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:com.cisco.io.StreamCorruptedException: invalid type code: 04; unable to load expression; ensure all custom classes are available; nested exception is:
5568: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        java.io.StreamCorruptedException: invalid type code: 04
5569: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readResult(Expression.java:2340)
5570: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readObjectCurrentVersion(Expression.java:2355)
5571: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readObject(Expression.java:2294)
5572: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5573: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5574: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5575: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5576: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5577: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5578: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5579: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5580: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5581: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObjectCurrentVersion(StepAssign.java:254)
5582: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObject(StepAssign.java:225)
5583: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5584: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5585: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5586: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5587: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5588: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5589: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5590: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5591: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5592: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObjectCurrentVersion(WFBeanStep.java:537)
5593: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObject(WFBeanStep.java:401)
5594: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
5595: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5596: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5597: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5598: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5599: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5600: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5601: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5602: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.util.DoublyLinkedList.readObject(DoublyLinkedList.java:333)
5603: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5604: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5605: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5606: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5607: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5608: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5609: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5610: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5611: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5612: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObjectCurrentVersion(WFWorkflow.java:1115)
5613: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObject(WFWorkflow.java:860)
5614: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5615: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5616: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5617: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5618: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5619: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5620: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5621: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5622: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5623: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.load(WFWorkflow.java:267)
5624: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.loadInternal(ScriptManagerImpl.java:301)
5625: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.load(ScriptManagerImpl.java:2179)
5626: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.Script.load(Script.java:370)
5627: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.Script.load(Script.java:389)
5628: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1054)
5629: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1308)
5630: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.actions.OpenFileAction$1.run(OpenFileAction.java:56)
5631: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
5632: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:721)
5633: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.access$200(EventQueue.java:103)
5634: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:682)
5635: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:680)
5636: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.security.AccessController.doPrivileged(Native Method)
5637: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
5638: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.dispatchEvent(EventQueue.java:691)
5639: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
5640: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
5641: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
5642: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
5643: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
5644: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
5645: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        nested stack trace is:
5646: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        java.io.StreamCorruptedException: invalid type code: 04
5647: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1374)
5648: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1964)
5649: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1888)
5650: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5651: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5652: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5653: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readResult(Expression.java:2322)
5654: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readObjectCurrentVersion(Expression.java:2355)
5655: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.expression.Expression.readObject(Expression.java:2294)
5656: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5657: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5658: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5659: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5660: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5661: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5662: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5663: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5664: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5665: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObjectCurrentVersion(StepAssign.java:254)
5666: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObject(StepAssign.java:225)
5667: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5668: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5669: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5670: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5671: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5672: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5673: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5674: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5675: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5676: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObjectCurrentVersion(WFBeanStep.java:537)
5677: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObject(WFBeanStep.java:401)
5678: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
5679: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5680: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5681: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5682: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5683: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5684: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5685: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5686: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.util.DoublyLinkedList.readObject(DoublyLinkedList.java:333)
5687: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5688: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5689: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5690: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5691: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5692: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5693: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5694: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5695: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5696: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObjectCurrentVersion(WFWorkflow.java:1115)
5697: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObject(WFWorkflow.java:860)
5698: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5699: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5700: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5701: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5702: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5703: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5704: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5705: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5706: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5707: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.load(WFWorkflow.java:267)
5708: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.loadInternal(ScriptManagerImpl.java:301)
5709: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.load(ScriptManagerImpl.java:2179)
5710: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.Script.load(Script.java:370)
5711: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.script.Script.load(Script.java:389)
5712: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1054)
5713: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1308)
5714: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at com.cisco.wfframework.editor.actions.OpenFileAction$1.run(OpenFileAction.java:56)
5715: Mar 27 10:06:31.449 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
5716: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:721)
5717: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.access$200(EventQueue.java:103)
5718: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:682)
5719: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:680)
5720: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.security.AccessController.doPrivileged(Native Method)
5721: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
5722: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventQueue.dispatchEvent(EventQueue.java:691)
5723: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
5724: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
5725: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
5726: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
5727: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
5728: Mar 27 10:06:31.465 CST %MEDT-SCRIPT_MGR-3-EXCEPTION:        at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
5729: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-UNK:Failed to load script: C:\test.aef; nested exception is:
        java.io.StreamCorruptedException: invalid type code: 04: Exception=com.cisco.script.ScriptIOException: Failed to load script: C:\test.aef; nested exception is:
5730: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:com.cisco.script.ScriptIOException: Failed to load script: C:\test.aef; nested exception is:
5731: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        com.cisco.io.StreamCorruptedException: invalid type code: 04; unable to load expression; ensure all custom classes are available; nested exception is:
5732: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        java.io.StreamCorruptedException: invalid type code: 04
5733: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.loadInternal(ScriptManagerImpl.java:316)
5734: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.load(ScriptManagerImpl.java:2179)
5735: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:370)
5736: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:389)
5737: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1054)
5738: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1308)
5739: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.actions.OpenFileAction$1.run(OpenFileAction.java:56)
5740: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
5741: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:721)
5742: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.access$200(EventQueue.java:103)
5743: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:682)
5744: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:680)
5745: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.AccessController.doPrivileged(Native Method)
5746: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
5747: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEvent(EventQueue.java:691)
5748: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
5749: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
5750: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
5751: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
5752: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
5753: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
5754: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        nested stack trace is:
5755: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        com.cisco.io.StreamCorruptedException: invalid type code: 04; unable to load expression; ensure all custom classes are available; nested exception is:
5756: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        java.io.StreamCorruptedException: invalid type code: 04
5757: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readResult(Expression.java:2340)
5758: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readObjectCurrentVersion(Expression.java:2355)
5759: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readObject(Expression.java:2294)
5760: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5761: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5762: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5763: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5764: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5765: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5766: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5767: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5768: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5769: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObjectCurrentVersion(StepAssign.java:254)
5770: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObject(StepAssign.java:225)
5771: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5772: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5773: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5774: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5775: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5776: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5777: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5778: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5779: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5780: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObjectCurrentVersion(WFBeanStep.java:537)
5781: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObject(WFBeanStep.java:401)
5782: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
5783: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5784: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5785: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5786: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5787: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5788: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5789: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5790: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.util.DoublyLinkedList.readObject(DoublyLinkedList.java:333)
5791: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5792: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5793: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5794: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5795: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5796: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5797: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5798: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5799: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5800: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObjectCurrentVersion(WFWorkflow.java:1115)
5801: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObject(WFWorkflow.java:860)
5802: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5803: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5804: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5805: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5806: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5807: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5808: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5809: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5810: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5811: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.load(WFWorkflow.java:267)
5812: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.loadInternal(ScriptManagerImpl.java:301)
5813: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.load(ScriptManagerImpl.java:2179)
5814: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:370)
5815: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:389)
5816: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1054)
5817: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1308)
5818: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.actions.OpenFileAction$1.run(OpenFileAction.java:56)
5819: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
5820: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:721)
5821: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.access$200(EventQueue.java:103)
5822: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:682)
5823: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:680)
5824: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.AccessController.doPrivileged(Native Method)
5825: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
5826: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEvent(EventQueue.java:691)
5827: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
5828: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
5829: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
5830: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
5831: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
5832: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
5833: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        nested stack trace is:
5834: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        java.io.StreamCorruptedException: invalid type code: 04
5835: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1374)
5836: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1964)
5837: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1888)
5838: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5839: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5840: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5841: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readResult(Expression.java:2322)
5842: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readObjectCurrentVersion(Expression.java:2355)
5843: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.expression.Expression.readObject(Expression.java:2294)
5844: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5845: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5846: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5847: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5848: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5849: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5850: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5851: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5852: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5853: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObjectCurrentVersion(StepAssign.java:254)
5854: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.steps.core.StepAssign.readObject(StepAssign.java:225)
5855: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5856: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5857: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5858: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5859: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5860: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5861: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5862: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5863: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5864: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObjectCurrentVersion(WFBeanStep.java:537)
5865: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFBeanStep.readObject(WFBeanStep.java:401)
5866: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
5867: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5868: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5869: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5870: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5871: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5872: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5873: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5874: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.util.DoublyLinkedList.readObject(DoublyLinkedList.java:333)
5875: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5876: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5877: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5878: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5879: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5880: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5881: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5882: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5883: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5884: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObjectCurrentVersion(WFWorkflow.java:1115)
5885: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.readObject(WFWorkflow.java:860)
5886: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
5887: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
5888: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
5889: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.lang.reflect.Method.invoke(Method.java:601)
5890: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1004)
5891: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1866)
5892: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1771)
5893: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1347)
5894: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
5895: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.obj.WFWorkflow.load(WFWorkflow.java:267)
5896: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.loadInternal(ScriptManagerImpl.java:301)
5897: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.impl.ScriptManagerImpl.load(ScriptManagerImpl.java:2179)
5898: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:370)
5899: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.script.Script.load(Script.java:389)
5900: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1054)
5901: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.workflow.WFDesktopManager.openWorkflow(WFDesktopManager.java:1308)
5902: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at com.cisco.wfframework.editor.actions.OpenFileAction$1.run(OpenFileAction.java:56)
5903: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
5904: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:721)
5905: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.access$200(EventQueue.java:103)
5906: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:682)
5907: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue$3.run(EventQueue.java:680)
5908: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.AccessController.doPrivileged(Native Method)
5909: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
5910: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventQueue.dispatchEvent(EventQueue.java:691)
5911: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
5912: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
5913: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
5914: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
5915: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
5916: Mar 27 10:06:31.465 CST %MEDT-DESKTOP-7-EXCEPTION:        at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
1) Are you able to open the script in CCX7 editor?
2) If so, have a look through the script for any unusual steps, or export it to text and post it up for review. You can post the script, screen grab it with steps expanded, or print it to a pdf or similar.
3) Test.aef suggests this might not be a prod script anyway - if you didn't rename it to this, perhaps check if it's actually assigned to any apps and whether those apps have been called recently.
Aaron
Unable to assign it to an application, it will prompt error occurred when loading the script.
i will try to find ccx7 editor to open it..
thx
Did you ever solve this issue?
Arundeep Nagaraj
Hi Melany,
Yes there is a lot of compatibility issues from a script designed on 7.0 to a script opened on the editor from the 10.6 version.
Are you using Custom jars? Can you re-open the script on the 7.0 editor and rebuild it on the 10.6 editor?
Arundeep
hi Arundeep,
how to rebuild it on the 10.6 editor? re-create the script in the new editor?
Elizabeth_GM
Melany, your script contains custom java class? If so, the java version for custom class of each server are differents :
Cisco Unified CCX and Cisco Unified IP IVR, Release 7 :
Sun JRE 1.5.0_011
Sun JRE 1.5.0_014
Sun JRE 1.6.0_12
(You could check the Cisco Unified Contact Center Express and Cisco Unified IP IVR Software and Hardware Compatibility Guide for Release 6.0(x), 7.0(x), and 8.0(x) to look for your exact version )
Unified CCX Software Compatibility Matrix for 10.6(1):
Sun JRE 1.7.0_40
You will need to compile the custom java class in order to be supported in the server v.10.
There is a post Integration Custom JAVA application with UCCX 10.0 that explains how to do it:
https://supportforums.cisco.com/document/12336156/integration-custom-java-application-uccx-100
Good look!
voipleo
I resolved by restarting CCX Administration service.
