Uccx Script doesn't work it directs immediately to ports
Phoenix3
Good Evening ,
I am working on creating IVR for our service desk
It should work as the following :
Welcome user and ask them to press :
1 for existing ticket
--> get ticket number
-->direct them to available agent
-->prompt agent  to html link that contain a  link added to it the ticket number
2 for other requests
--> direct them to any available agent
but whenever I tried to debug it gets a lot of error
and if I called it directs me immediately to any agent even if there is non available.Capture.PNG
Phoenix3
It appears that issue was in the audio files .
I used this website to change their settings https://g711.org/  to u-law WAV (8Khz, Mono, u-law)
8 Replies 8
Mike_Brezicky
So first - Does your Prompt - WelcomePrompt play the menu options 1/2? I would have that play under the Menu settings. Chances are, it may just be rolling to unsuccessful or Timeout selection.
I would suggest testing one scenario at a time. The simplest is Option 2, make sure you get the prompt, press 2, and the correct queue is being selected. After that, then add in / test option 1.
We cannot see past this section as for the Menu > Unsuccessful / Timeout paths. or beyond, so in your option 1, its unsure where the script goes after success of the digit entry and http forward.
yes the welcome contain the "press one for ..."
when I try to run the code I get "AcceptStep: Trigger is not a ContactApplicationTrigger"
I would move the WelcomePrompt into the Menu settings as its prompt and not a separate line. Without that, your selection is not really applying as the prompt is playing before the menu step takes place.
I removed the prompt and had the menu play the prompt .. but till now it does not work .. I get the same error and when I call it direct me immediately to one of the ports
Konstantin Vaksin
Why do you create URL in the script?
Easy way to open page with URL from the call:
1. Store SR number in CallVariable1 (as example)
2. Create Workflow to open HTTP Browser page, when call is received. Use CallVariable1 parameter in the URL
how do I create workflow ? I am new to this and Cisco guide are not easy
Phoenix3
