12-17-2021 09:10 AM
Solved! Go to Solution.
12-17-2021 09:57 AM
So you set the string in a parameter for examplve strBody = "grant_type=urn:ietf:params:oauth:grant-type:jwt-bearer&assertion=" Then you set strBody in your REST request. Can you validate what the API is receiving? That will make your life a lot easier to figure out what might be going on.
david
12-17-2021 09:57 AM
david
12-17-2021 10:10 AM
Excuse me,
I'm half bad at this subject of programming things, these are all the parameters that I need to send in the BODY.
This can be done as you told me?
12-17-2021 12:03 PM
12-17-2021 12:54 PM
12-22-2021 04:50 AM
I think the problem is in how I am sending the BODY.
I need to send some variables in Form-Data format, how does UCCX accept it in the Make rest Call step?
Thank you
05-30-2023 10:12 PM - edited 05-30-2023 10:12 PM
did you find solution for this problem . i am also facing same isssue, need to make Oauth call and in that need to pass body as form data type
02-06-2024 08:57 AM
Hi. Same here. Any Update? Thank you!
