UCCX Subflow issue with Write document step
Scott Brien
We are currently having an issue with our subflow script which alters an XML file.
This Script has been functional in the past however it was when we were running UCCX 7.0 on windows and we used the windows paths to reference the XML document.
We have migrated to the Document repository and have worked through most errors like replacing the create file document step with the Create XML Document step however we receive the following error on the Write Document step:
AccessControlException:access denies (java.io.FilePermission DOC[/XMLs/business_fwd.xml] read)
I have attached the Script and XML documents.
Any help would be greatly appreciated.
Scott
23 Replies 23
Jonathan Schulenberg
You must authenticate a user before you can write a document to the repository. You need at least the Get User (input userID) and Authenticate User to do this.
From the: Scripting and Development Series: Volume 2, Expression Language Reference for Cisco Unified CCX and Cisco Unified IP IVR, Release 8.5(1)
Note This step is required in a script before you can use the Upload Prompt, Upload Grammar, or Upload Document step in that script. Only an authenticated user can upload a prompt, grammar, or document.
We have added the Get user and authenticate step which are both succesful, however the error is still showing.
Any ideas?
Scott
You need to use the Upload Document step to write the document to the Document Repository.
Tanner Ezell www.ctilogic.com
We are working on the upload step now, however we run into the issue where the document upload is unsuccesful and when we modify the upload step we can no longer call the route point and receive the system troubles notification.
Are any services reporting PARTIAL_SERVICE or OUT_OF_SERVICE?
All services are In Service
Is validation of the script successful? (Tools --> Validate)
Script Validates fine, we were able to debug, then we changes a setting in the upload Document step and the error started to occur and we can't even use reactive script.
I have attached the Upload document step below
In your Upload Document step do you have the DOC[foobar] in quotes? If so, remove them.
Only the name in the upload document step is in quotes.
The document does not have quotes
Can you screen shot the Upload Document properties window.
no problems, See below
Remove the quotes from the Names field.
