UCCX Subflow issue with Write document step
Scott Brien
We are currently having an issue with our subflow script which alters an XML file.
This Script has been functional in the past however it was when we were running UCCX 7.0 on windows and we used the windows paths to reference the XML document.
We have migrated to the Document repository and have worked through most errors like replacing the create file document step with the Create XML Document step however we receive the following error on the Write Document step:
AccessControlException:access denies (java.io.FilePermission DOC[/XMLs/business_fwd.xml] read)
I have attached the Script and XML documents.
Any help would be greatly appreciated.
Scott
23 Replies 23
Error "expecting string"
Sorry, you only need the "business_fwd.xml"
You only invoke DOC[foobar] when you want to pull the file. Saving it just requires the name.
Tanner Ezell www.ctilogic.com
Removed the DOC and only had "business_fwd.xml".. still no joy unfortunately, we can now debug the script again though, and we see the upload step hitting unsuccesful...
Dumb question, do both the Get User and Authenticate User steps succeed?
If so, you may need to gather the MIVR logs and determine exactly why it's
failing.
both get user and auth user steps succeed
after looking through look MIVR logs we have found the following:
%MIVR-STEPS_DOCUMENT-7-DOCUMENT_UPLOAD_EXCEPTION:Executing: Task id=25000002875,Step=java.lang.SecurityException: controlled operation requires authenticated user.0290082334 is not authenticated user.
6874812: Sep 30 16:13:13.001 EST %MIVR-STEPS_DOCUMENT-7-EXCEPTION:java.lang.SecurityException: controlled operation requires authenticated user.0290082334 is not authenticated user.
6874813: Sep 30 16:13:13.001
However 0290082334 is an appadmin administrator/supervisor/agent
Any ideas?
Scott
Hi Scott
You have  a get user step, which is good..
Then an auth user, which references the userid again - this should reference the UserAuth object that you just obtained with the get user step. If you just reference the userid and PIN, you are basically 'testing' the auth, not authenticating your user object.. see?
You are already correctly using UserAuth for the actual upload step, but because the Auth User step hasn't done the business on UserAuth, it fails..
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
Thank you for the information there very helpful as we have had no need for the Auth or user steps for subflows etc in the past with the IPCX 7.x
Scott
We have resolved this issue, the error being that we were authenticating a user rather than the users extension, once this was changed fieles started uploading.Thank you for your help
