UCCX5 script writing help - Auto-transfer when queue busy
wmaccachran
I need help building (finding) a script that will evaluate if all agents in Queue1 are busy, so that a new call being sent into Queue1 would then automatically transfer to Queue2 (if Queue2 has available agents).
Live2 Bicycle
Level 3
Level 3
Wes,
Cisco has a script repository located at http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_implementation_design_guides_list.html
You can find the simple queueing script as a starting point.  You could then you an if statement to check agent status then send teh call to the other queue based on your criteria.
Let me know if you need anything else.
Del
Hi Wes,
Yes this is possible, you just need to use the get reporting statistic step, there you should take the number of agents that are ready. After that use an If step. Something like this:
Start
Accept
Get Reporting Statistic
if (readyAgents.equals(0))
True
     Go to Queue2
False
     Go to Queue1
Gabriel
