Variable in ICM call Flow
Rohit Khajuria
Hi All
I have a query. Please find attached the image for the reference.
CallQueue and Calling number will come from ICM as a input .
so  from which variable we will receive above two variable to finesse desktop ?
Thanks all in advance !!!
Omar Deen
Are you asking which variable will contain Call Queue and Calling Number (DNIS)? If so, that's entirely up to you...
Omar Deen
Can you please make me understand through some example ? I would appreciate it.
Let's use Call Peripheral Variable 1 and 2
You'll want to place a Set Variable node in your routing script calling on Peripheral Variable 1 and your value being Call.DialedNumberString. Place another Set Variable node in your routing script calling on Peripheral Variable 2 where you can enter a literal string (double quotes) for your queue name.
To display it in Finesse, log into CFAdmin, go to the Variables layout change the name for Variable 1 to be Dialed Number and Variable 2 to be Queue Name
